67 Vent window handle removal ???
I know you need to remove the roll pin to get the handle off. And I've read that you can use a small punch. But, I don't see an exit home. Do you just punch it all the way through ???
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
Yes. Be very careful! My batting average doing this without breaking the window is 50%.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
Then, walking across the shop to get the new handle to put on, I dropped it!! End result the same I guess. Ha. But I wasn't laughing at the time. Charles |
if you can use a broken drill bit (shank end)and a pair of channellocks
no need to tap on a drift pin
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Thanks for all the advice. I like the broken drill bit idea. Will give it a try tomorrow.
