Old 10-01-2021, 06:37 AM
Gnnrunner Gnnrunner is offline
Default '74 FORMULA 400 PS PUMP - WRONG FLOW CONTROL VALVE
Flow control valve in new power steeing pump (1974 Formula 400) not correct for reverse flare high pressure hose. My power steering pump was leaking at the flow control valve. I tried a new flow control valve, but it does not have a surface inside to mate with the reverse flare on the high pressure hose. I tried a new pump, but it came with a flow control valve that also does not mate correctly. Does anyone have a source for a correct flow control valve or pump?
