Old 08-21-2009, 01:46 PM
bulletpruf's Avatar
bulletpruf bulletpruf is offline
Chris - Got your PM.
Goatless - that's good info; wish I was closer to CT.
Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s
  #42
Old 08-22-2009, 12:18 AM
Guilty's Avatar
Guilty Guilty is offline
Default Tires for Scott's Ram IV:
Jeremy, just give Chris a few sets of tires and I'll get them from him and have them waiting in Stanton, so when Scott gets there, his extra tires will be there!!!!!! I am sure Chris will be ok with this. I'm just trying to be nice by getting the tires delivered to Scott and it was very nice of you to offer them in the first place.
  #43
Old 08-22-2009, 11:15 AM
goatless's Avatar
goatless goatless is offline
Well Scott... If you get to the point where you're ready to go and still need a set of tires, give me a shout. Brian (Guilty) has the ability to get them anywhere.
1966 GTO
  #44
Old 08-22-2009, 12:44 PM
bulletpruf's Avatar
Thanks again for the offers to assist. However, I don't think that the car will be ready for the track until next year.
Scott
  #45
Old 08-23-2009, 12:18 AM
JLHarper's Avatar
JLHarper JLHarper is offline
Scott, look forward to seeing it run next year.
I know it will be top notch, dialed in and roaring to go!
  #46
Old 08-30-2009, 09:53 PM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
hey scott this thread got me fired up so I loaded my car for the first time and drove it around the block a few times just for a trial.....smelled rubber burning when I got back, turns out I had to beat the squat out of right side trailer fender which did a nice job of rubbing some new rubber off inside tire sidewall. really pissed me off. good to go now. just have to decide when and where.
Name:	goat trailered.jpg
ID:	179707   Click image for larger version
Name:	goat trailered 2.jpg
70 GTO 400/4SPD-13.97@102.31
  #47
Old 08-31-2009, 12:19 PM
bulletpruf's Avatar
Slash - sorry to hear about your trailer. Are you going to race your car? Pure Stock? What 400, trans (M20?), and gear do you have?
Scott
  #48
Old 08-31-2009, 12:21 PM
bulletpruf's Avatar
Well, the RAIV motor is home & tucked away in the garage next to an AMC 401, Ford 427 tunnel port, a few RAIII's, etc. Need to install a few motors this winter, I guess.
FYI - computer dyno predicted a real strong number for hp, but Jim thinks it's a bit optimistic. Should be more than enough to be competitive, however...
Thanks,
Scott
  #49
Old 08-31-2009, 02:50 PM
4SLASH6's Avatar
scott, I would like to run it in pure stock up at brainard this weekend. big muscle car race/show. hear they get some 400 participants. 3 day event. problem being wife and kids wanna tag along and play at water park to the tune of about $200.00 a day/night. more likely I may hit a test and tune session at another strip in a few weeks. cost me $50.00 plus fuel there and back. a little more in my ball park. scott I have the #'s engine aside for some too early dated stock/correct 12 heads. .030 over 400/ wide ratio, 3:55's HD saf-t-trac cam is old school crane with similar grind to R/A 4 spec. I hear every track is tad different as to what to or not to allow although they want us to follow NHRA guidelines for class. this is mostly stuff I get off each strips website, not gospel. no purse money this weekend. I think if they really wanted to DQ me they could make me swap my adjustable front shocks,dig deep and see my R.A.R.E mannys are O.S. or not let me run at all for a 2 inch crack in my upper windshield if they see it and wanna get real fussy. like I said, I am most likely to hit a test and tune. tHen I can try my drag radials and not worry about anything. TOM
  #50
Old 08-31-2009, 03:08 PM
Ron Landis's Avatar
Cool LOL...
Originally Posted by bulletpruf View Post
Yep, another roundport to terrorize the Mopars, chebbys, and Fords! Thanks again for the great inspection you did on the car many moons ago. I need to e mail Ed and let him know that it's coming together.
Scott
Funny you should mention that! The BB Chebby guys around here are stompin' their feet because we claimed that the '69 RAIV would go 12s "as she sits"....bias ply tires...full exhaust and all. "No way" Well...the 13.09 off the trailer at 106+ has them wondering now. The second pass picked up the 60' from 2.17 to 2.06...which put us there, but she drove right thru the clutch in fourth and netted a 94 mph pass. We aim to fall back and regroup this week, as we had a custom clutch made by American Driveline which they guaranteed!!! So far...this is the third clutch in 700 miles. Seems those Zooms aren't what they used to be. Anyway...good luck with your build. We are looking at hitting the chassis dyno as well once all the bugs are tweaked out of her. Take care. Ron
  #51
Old 09-01-2009, 01:18 PM
bulletpruf's Avatar
Ron - Sounds like you'll easily be in the 12s. FYI - most folks I talk to are running the Centerforce dual friction clutch. Also, is yours a stock rebuild, to full Pure Stock specs (more compression, Pertronix, aftermarket exhaust, etc), or somewhere in between?
Scott
  #52
Old 09-01-2009, 01:20 PM
bulletpruf's Avatar
Tom - sounds like a fun ride. Let us know how you do if end up racing this weekend.
Scott
  #53
Old 10-12-2009, 06:38 PM
bulletpruf's Avatar
Latest news - I figured the front suspension and brakes needed a complete rebuild, the rear suspension needed the same, need to install a new ring and pinion, etc. When it was all removed, there's just a few bolts holding it on the frame, right? So I decided to take the body off the frame so I could sandblast and paint the frame. And while it's off the frame, I might as well paint it, right? Needs to go back to the original Pepper Green. Interior is in pretty good shape, but it could use a bit of sprucing up, too. Wiring is 40 years old, so might as well replace that. Time to install a Pypes exhaust. Need to rebuild the M21. New radiator. New front and rear valences. Did I miss anything?
As of right now, the front and rear suspension are off. Engine and trans are out. Seats and carpet are out. Body mount bolts are fighting me, so I'll probably have to do some cutting to get at 'em from the top. Hope to have the frame out soon.
Pics to follow. Hope it doesn't take forever to finish. At least the motor is done and the interior is in good shape.
Scott
  #54
Old 10-13-2009, 02:25 PM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
ah the mightaswells. know them well. and hope that doesn't happen with the front end rebuilt on the GT-37 this winter. of course I had planned to rebuild the M-21 as well. replace the cobled up POS exhaust system. and then .... well, you know
restorations, step into the abyss. :-)
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
  #55
Old 05-17-2010, 04:39 PM
67drake's Avatar
67drake 67drake is offline
I was thinking about this thread today as I try to figure out what to do this summer. I didn't get a chance to do much last year because of a lack of funds,but I'm hoping this year goes better. I'd be happy to make it out to see the races out in MI,even if I can't race.
Any updates you guys? Anyones car done? Is anyone going to the races in MI (I think it was June 25th)?
13.95 @ 102.1 on street tires @ 4055lbs.
  #56
Old 05-17-2010, 04:50 PM
bulletpruf's Avatar
It's off the frame. Working on details to send it to a PY member's shop for bodywork and paint. Looks like my RAIII Antique Gold Judge is sold, so that will provide much of the funds necessary to get things jump started.
Thanks,
Scott
  #57
Old 05-17-2010, 04:57 PM
I'm putting the exhaust on mine now. Will pick up control arms this week for a rebuild and put them on at the end of the month. I sent in my registration for the FAST/Factory Stock race June 25/26, so the GT-37 will be there. This will probably be the last race ..... with the current motor. New motor is being built and will be in the car in time for the Pure Stock Drags at Stanton in Sept.
TH400/3.08 open
  #58
Old 06-21-2010, 12:52 PM
bulletpruf's Avatar
Thanks,
Scott
Car was delivered to Supercar Creations in Barberton, Ohio. Owned by Darrell Davidson, PY member and GTOAA Judge. I've seen his work - quite impressive.
Motor is done, I'll rebuild the trans, and restore the frame and suspension. Darrell will handle bodywork, paint, interior, etc.
Scott
  #59
Old 06-21-2010, 03:18 PM
good to hear Scott.
for those interested, I completed the exhaust, finished up the front end rebuild and converted it to manual steering. Got it aligned this past Sat and she's ready to rock and roll for this weekend's race.
TH400/3.08 open
  #60
Old 09-03-2010, 08:27 PM
two weeks from today and the first day of the PSD will have been completed. Sadly, the new motor isn't ready. I don't want it rushed to get it in and ready, do it once, do it right, so it'll be about another month. A little bummed, but thats fine as I'm that close. This gives me more time to fix a few things here and there on the car and continue to practice launching the car.
There is talk of a FAST/FS race at US131 in Martin at the end of Oct, so thats the new goal for the new mill. We'll see what happens.
As for the improvements/changes/fixes I did prior to the Martin race in June. It's amazing what a good exhaust system will do for the breathing on the engine. shaved 1/2 a second and gained 3mph.
TH400/3.08 open
