Old 04-02-2024, 08:29 AM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
Default RobbMC Fuel Pump Users Question
For use with an IA2 block, any mods required to the 1100HP pump to fit correctly?
I asked Robb via email and he said he wasn’t sure with the All Pontiac block. MR1 requires some light clearance to work.
Thanks in advance.
Old 04-02-2024, 09:01 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Not an actual user but cam and timing set and timing cover are all
In the same place w an ia2 as a stock block should
Be fine only Difference is on oil pan rail and that should not effect pump Unless the added material around the bore, (to gain support) hits the body of the pump? I guess that would be possible but I’d go to an electric pump Before I ground my block if it was me
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
The Following User Says Thank You to mysticmissle For This Useful Post:
