OHC-6 TECH Over Head Cam projects, questions and advice.
Old 12-18-2018, 06:44 AM
Jeff Hamlin's Avatar
Question TIMING BELT COVER SCREWS
I thought there was a post with info on suitable replacement SCREWs for the (3) mounting screw used on the Timing Belt Cover but can't seem to locate it.
Anyone have this info; ?
IIRC they were sourced from a Motorcycle parts sight.
Thx.
Old 12-19-2018, 07:29 AM
Thumbs up FOUND IT/THEM...
The OE screws for the 66-68 Belt Cover always seem to be missing.
These are a great alternative part to use.
If anyone has 3 OE to sell LMK.
Cheers.
Old 12-19-2018, 01:11 PM
Bill's 68 Bill's 68 is offline
Looks like a pretty good substitute. I.ve looked for new ones for a long time and never found anything closer than that. I assume the longer threads have no effect? Thanks for the info, Jeff.
Old 01-31-2019, 07:36 AM
Thumbs up
Not much activity when it's so cold,
I did however finally get a set of these myself and must say these are almost spot on.
I searched out a set a little less costly with a slightly less shiny finish.
These are 5/16 - 24 X 9/16 Truss Head Screws.
Old 03-04-2019, 10:28 PM
sprint6ohc's Avatar
sprint6ohc sprint6ohc is offline
Default Timing belt cover screws
I seem to remember there was a post about this. Someone found them on Ebay. ???
Old 03-06-2019, 07:26 AM
Thumbs up
Yes, Post #2 shows the HD offerings found on EPAY.
If you search around you can find better deals.
