Old 02-29-2024, 02:17 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
Originally Posted by i82much View Post
I am gonna do this with all my ex-girlfriends. Will post up pics and weights soon!!
Wouldn't hurt my feelins if ya skip the hefty ones...
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
The Following User Says Thank You to 4zpeed For This Useful Post:
  #62
Old 02-29-2024, 10:02 AM
i82much's Avatar
i82much i82much is offline
Frank
Let's just say the bead blasting did NOT go over well.
  #63
Old 03-01-2024, 10:43 PM
BLUE TA's Avatar
BLUE TA BLUE TA is offline
parts place ho intake. shipping weight 17 lbs.
  #64
Old 03-12-2024, 03:38 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Default 1967 Firebird 400 4bbl intake
apologies if any repeats, but I have a few manifolds and took the time to weigh them to contribute here.
first up, a 1967 Firebird 400 4bbl intake. It has one plug on it that might take more time to remove than I had over my lunch break to take all these pics so it stayed on. otherwise, this was the heaviest manifold in my stash weighing in at 39.3 lbs.
Next, a 1969 4bbl intake. This came out of my GTO but I don’t know what it was originally from as my engine isn’t original. This one was slightly less at 38.3 lbs.
ID:	630283   Click image for larger version
ID:	630284   Click image for larger version
ID:	630285   Click image for larger version
ID:	630286   Click image for larger version
Long live the Muscle Car
Instagram @tuske427
1967 Firebird #BVbird
1967 Firebird 400 4 speed project
1969 Verdoro green GTO (daily)
The Following User Says Thank You to Tuske427 For This Useful Post:
  #65
Old 03-12-2024, 03:44 PM
Tuske427's Avatar
Default 67 vs 69 Pontiac 4bbl intakes
Going off on a tangent- as I was doing this I got curious as to the changes between these two intakes that, at first glance, might be taken as identical. Yet, the closer I looked more I noticed the differences. quite a bit of them, actually.
- carb mounting flange shape
- groove on the 67 carb flange
- pressed in vs screw in plugs
- less pipe threaded holes drilled
- lack of casting info on the bottom
- 1 vs 2 bolt holes for the choke spring
- casting # info and locations
ID:	630288   Click image for larger version
Instagram @tuske427
The Following 3 Users Say Thank You to Tuske427 For This Useful Post:
  #66
Old 03-12-2024, 03:47 PM
Tuske427's Avatar
Default ’71 HO 4bbl and Edelbrock Torker II
I also have this ’71 HO intake I’m storing for a friend (He will sell it for the right price btw) and a new Torker 2.
the ’71 weighs 13.2 lbs without the crossover and 18.8 lbs with it.
The Torker 2 weighs 14 lbs
ID:	630290   Click image for larger version
ID:	630291   Click image for larger version
ID:	630292   Click image for larger version
ID:	630293   Click image for larger version
Instagram @tuske427
The Following 2 Users Say Thank You to Tuske427 For This Useful Post:
  #67
Old 03-12-2024, 03:50 PM
Tuske427's Avatar
Default Edelbrock Torker 2
additional post since I’m limited to 5 attachments per reply…
ID:	630295   Click image for larger version
ID:	630296   Click image for larger version
Instagram @tuske427
  #68
Old 03-12-2024, 08:36 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Talking Intake
Been trying this setup that I installed a few weeks ago.
Definitely keeps carb and runners cooler. Motor seems really
happy with it aswell.
9799068 with seperated water crossover and repop 69
Exhaust crossover.
Gerry
ID:	630305   Click image for larger version
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds
  #69
Old 03-12-2024, 09:12 PM
242177P's Avatar
242177P 242177P is offline
FIREING. I both hate and love seeing that.
  #70
Old 03-12-2024, 10:03 PM
Tuske427's Avatar
LOL hadn’t noticed that. Were they all like this in ‘67, or just a small batch of them?
Instagram @tuske427
  #71
Old 03-12-2024, 10:37 PM
242177P's Avatar
Small batch. I've seen several on the internet.
They're unusual, but I wouldn't call them rare.
The Following User Says Thank You to 242177P For This Useful Post:
