Old 01-19-2024, 01:41 PM
vwmailman vwmailman is offline
Default 69 gto tilt column
I have a friend looking for a 69 gto tilt column. My question is , are there any differences in the 69-72 gm a body tilt columns? Are the tilt & turn signal levers same? Thanks
Old 01-19-2024, 06:06 PM
1969GiPper 1969GiPper is offline
1969-72 G-body (Grand Prix, Monte Carlo, cutlass supreme) should also fit.
The Following User Says Thank You to 1969GiPper For This Useful Post:
Old 01-19-2024, 06:18 PM
tstroud tstroud is offline
The ignition switch and wiring changed in 71 but you only have to move 1 wire in the connector.
Old 01-19-2024, 06:20 PM
I believe the 70-72 interchanges but they did relocate the alignment groove on the lower shaft (rag joint connection) by 90 degrees some time in 1970-71. Easy to just grind a new groove. Only proviso is if it's a column shift, only Pontiac's had the shift indicator on the column. Also, Pontiac turn signal and tilt levers are unique (appearance only, they do interchange functionally) and iirc the turn signal lever is different on a tilt vs non tilt column.
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
Old 01-20-2024, 08:48 AM
Thanks for the info!
