Old 01-31-2008, 04:06 PM
Keith Seymore's Avatar
I think what they are saying is this:
Where the steering knuckle attaches to the lower control arm: instead of the knuckle sitting on top of the arm, they flipped the ball joint so now the knuckle attaches below the arm. That way as you add spacers the knuckle moves down with respect to the control arm attachment or, from the ground's point of view, the front of the car is raised.
The spacers on the top (visible in the picture) are to gain back some of the travel lost in the "jounce" direction, so that the suspension is not immediately topped out during upward travel.
My car also has ball joint spacers on it (perhaps made from the same batch) but as I say it is to allow more front end lift during acceleration thereby aiding traction.
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
  #62
Old 01-31-2008, 04:33 PM
Jurassicgto's Avatar
Jurassicgto Jurassicgto is offline
OK, the lower ball joint points down to the ground? There would have to be enough clearance around the outboard end of the lower control arm so it wouldn't hit the steering knuckle/spindle. Think thats possible? Thanks for your help in understanding this. I raised my front end a bit using taller springs and aluminum ball joint spacers but couldn't get anywhere near the lift these guys did.
  #63
Old 01-31-2008, 05:36 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
JurasicGTO, do you need ALL that much more lift? If not, have you tried loosening your sway bar? Loosen the ends of the links and drill out the front bushings. That will give you some extra lift.
  #64
Old 01-31-2008, 06:12 PM
Do I need that much more lift? Probably not. Do I want that much more lift? Oh yeah! Front sway bar is gone. Loosened control arm bolts and bushings. My car is much heavier than Unswitchable. Stock front end except for fiberglass bumper, hood and the new plastic grilles.
  #65
Old 01-31-2008, 10:48 PM
6567GTO's Avatar
6567GTO 6567GTO is offline
Cool stuff Keith! Never heard it explained out before. Always wondered.
  #66
Old 02-01-2008, 10:37 AM
You are welcome, although I don't think they are being entirely up front with us in the article.
See the steep angle on the lower control arms when viewed from the front? Mine are much more horizontal, and I don't think you are going to change that without heavier/longer/stiffer front springs. Even though the article says specifically they re-used the stock springs I tend to doubt it.
K
'63 Grand Prix
  #67
Old 02-02-2008, 01:39 PM
K
Having given this some more thought I am going to retract that statement.
If they took as much weight off the front end as I think they did, plus by moving the rear wheels forward (and shifting more weight rearward) then that front end will come up quite a bit. They probably could re-use the stock springs and get that much lift in conjunction with all the weight removed.
I am, however, NOT going to retract the part about them not being entirely straightforward in other areas. There are a couple items I think are "suspect"...
K
'63 Grand Prix
  #68
Old 02-02-2008, 02:07 PM
Looks like they used spacers between the frame and body to get the body higher also.
  #69
Old 02-02-2008, 02:13 PM
Thumbs up Lightweight grille
Phil,
You really need to put a Tempest grille in your car.
Bart
  #70
Old 02-02-2008, 06:00 PM
6567GTO's Avatar
Actually Bart, I have a custom set (made by John Gunther) of GTO grilles that are made out of aluminum sheet metal. They look pretty much like the originals and are light as hell.
Originally Posted by b-man
Phil,
Bart
  #71
Old 05-11-2009, 02:41 AM
6567GTO's Avatar
Default Man it's been a while...
and not much progress. I had to pull the car out of storage after losing the space. So here she is. I need some motivation so kick my arse people. Get me going again.... please!!
ID:	168207   Click image for larger version
ID:	168208   Click image for larger version
ID:	168209   Click image for larger version
_________________________
Sonny Barger
  #72
Old 05-11-2009, 07:38 AM
The Boss's Avatar
The Boss The Boss is offline
Last time I saw that trailer somebody was camping on it!
Get moving!
And go racin' in the street.
  #73
goatless's Avatar
goatless goatless is offline
C'mon Phil you've got a the hard stuff done! We've got tto get you back into the Pontiac state of mind- forget about the damn Harley and Mopar. Jim, Chris and myself really are going to have to come down there aren't we.
Musclepalooza is on the 24th up at LVD. If anything is going to get you motivated that'll do it, seeing all of those show cars and the race cars tearing up the track.
1966 GTO
  #74
Old 05-11-2009, 08:11 AM
Rob B's Avatar
Rob B Rob B is offline
There you go! Get the boy back on track! He's got a little under 3 months to get it ready for Norwalk!!!
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
  #75
Old 05-11-2009, 08:25 AM
Hooter's Avatar
Hooter Hooter is offline
I think it's time for Jim, Jeremy, and Chris to make a trip to your place for a "Pontiac" intervention to get this thing off ground zero again. Looks great with most of the hard stuff done. Quit chasing the split tail a few nights a week and dedicate it to this project....
67 Bonneville ragtop
  #76
Old 05-11-2009, 10:17 AM
60man's Avatar
60man 60man is offline
Well....get at it "Scooter Boy"...
What's keeping ya from getting it done..Harleys,MOPARs.or Hmmmmmmm
Just got to share your time...
Hope you get it done soon. Looking good...Should be a thriller ride !!!
Hope to catch up with ya soon Phill..
Don't forget my moto !!
On another note...I was surprised to see the 58 rear in Dick Jesse's car complete with the funky "U" shape upper control arm. I couldn't wait to get that of my 60 !!! Nothing wrong with diff...just that upper control arm..
ECM member.
MANDRA
  #77
Old 05-11-2009, 10:22 AM
K
Those may be stock springs on Unswitchable but I'lll bet there're Spacers in between the spring and the frame that you can't see. They're probably a 6 cyl spring also, They tend to unload quicker forcing the chassis down on the rear.
That's my guess, there's waaaayyy too much hieght on that chassis for a correct application spring.
Mike
former." --Albert Einstein
- Winston Churchill
  #78
Old 05-11-2009, 11:20 AM
Jerry H.'s Avatar
Although no where near a 'gasser' or as radial as your car, maybe this is a little motivation.
  #79
Old 05-11-2009, 08:10 PM
wd45gto's Avatar
wd45gto wd45gto is offline
that car looks great jerry!!!!
64 tempest wagon 421 gasser
  #80
Old 05-12-2009, 10:39 AM
wd45gto's Avatar
65 gassers rock! thanks for all your insperration and photos. need motavation just reread your thred,its got me motavated.(sorry dont spel well)
