Old 02-03-2020, 04:29 PM
eric_cspan's Avatar
eric_cspan eric_cspan is offline
Administrator
Default 64-67 GTO A/C Radiator Supports!
Very soon, AC radiator supports will soon be available! GTO owners have been stuck spending stupid money for rotted used ones for years...Now we created a new solution.
A. Lower AC Support Panel: We will be offering the lower AC support panel piece by itself. Drill out the welds in your non AC original support. Then re tack in this lower channel piece. Wha lah! You now have an AC support that is capable of fitting the taller 17.5" radiator.
B. AC Support: We will also be making our own full supports. We will take a reproduction non AC support and convert it to an AC version with our lower support panel. For those not wanting to do the grunt work of modifying their originals.
Our production run is happening now so look for these pieces at Pontiac dealers later this Spring!
ID:	531039   Click image for larger version
"LIKE" Max Performance on Facebook!
"LIKE" Cold Case Radiators on Facebook!
"LIKE" GTOG8TA.COM on Facebook!
The Following User Says Thank You to eric_cspan For This Useful Post:
Old 02-03-2020, 09:48 PM
pgp66's Avatar
pgp66 pgp66 is offline
Awesome, thats great news, thanks.
--> 1966 Pontiac Le Mans Convertible, Martinique Bronze, black top, Parchment interior, alloy Rallye 2's, M/T Sportsman ST's 235f/255r with redlines, 464 (455 .040 over), Performer RPM 87cc round port heads, Butler roller cam, Edelbrock Pro-Flo 4, Ram Air 2.5" manifolds, 67 GTO Ram Air pan, 2.5" Magnaflow, Muncie M22, 3.55 Eaton Posi. <--
Old 04-16-2020, 03:28 PM
RA66GTO's Avatar
RA66GTO RA66GTO is offline
Any update on this amazing project?
1966 GTO Resto-Mod. 2nd owner California car, factory Air, Power Windows, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R, Yank 2400 Stall Converter, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust M, Continental Extreme Contact DW
Old 04-16-2020, 08:25 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
A) lower AC support is in stock.
b) full AC supports will be ready in May.
We're doing them in house with limited staff. So if you want one, it's best to call in and get one ordered.
Old 04-16-2020, 08:55 PM
64speed's Avatar
64speed 64speed is offline
Do you have these for 64
Old 04-16-2020, 09:33 PM
Will call tomorrow, working on a '67.
Old 04-16-2020, 09:54 PM
Ccass's Avatar
Administrator
We believe the lower kit will work on a 1964 but we have not been able to find a 1964 'small' support to confirm.
We do not plan on making the 1964 full support. The reason we are offering the 66-67 AC support is because the non ac support has been reproduced. So we are using those to make the 66-67 AC supports.
