Old 02-14-2020, 12:44 PM
dataway's Avatar
dataway dataway is offline
Default Electronics Gurus Please
I've got one for you nerds. I need a power transistor ... original is a Toshiba A968 Y 9H. I think a 2SA968 will work? TO-220 case, PNP.
No go at Allied, or DigiKey. See some similar things on ebay ... hear there are lots of fakes.
I can't find a direct cross reference to a current, name brand, easy to buy equivalent.
Trying to repair an old 1988 Pioneer Tuner/Amp
Old 02-14-2020, 02:02 PM
Shiny Shiny is offline
I'm far from a guru but wouldn't worry too much about counterfeit vintage parts... not much money to be made by criminals in low-volume parts!
If it were me, I'd just go with the closest available... for example this one on eBay:
https://www.ebay.com/itm/1PAIR-OR-2P...-/401500432058
Hopefully the suffix is a date code and any 2SA968 will work.
If you need to locate an equivalent, you may need to provide a schematic for a guru. Do you have one?
Old 02-14-2020, 02:06 PM
Stuart's Avatar
Stuart Stuart is offline
Mouser is another big electronics supply house, you could try there. I saw some on Ebay as well, but then also read an older post on an electronics forum that mentioned the possibility of fakes. This discussion suggests a couple newer transistors that are apparently compatible replacements: https://www.diyaudio.com/forums/part...8-2sa2238.html
The Following User Says Thank You to Stuart For This Useful Post:
Old 02-14-2020, 04:08 PM
dataway's Avatar
Thank you gentlemen.
I was looking at that very pair on ebay myself. Probably close enough.
After digging a little farther I find that both the output transistors on that channel are also toast. Along with various resistors associated.
Not sure that this project is going to be worth the trouble.
Weird when you look back at 1988 and think, hey that wasn't that long ago ... and you discover everything is obsolete
Old 02-14-2020, 07:54 PM
Stuart's Avatar
It's funny how 32 years doesn't seem like a long time anymore.
Old 02-15-2020, 02:25 AM
beertracker's Avatar
beertracker beertracker is offline
I would contact the Toshiba rep through this form. https://www.toshiba.com/taec/support/techquestions/ Fill it out and ask for samples of the A968 Y 9H transistor. When I working in the electronics industry it was common for reps to provide samples. Your other option is to attend a ham radio fest and look around for the transistors you need.
Also since you are going to replace a single channel power transistor I would replace the other channel as well with the same part number just to be safe. Get two identical power transistors.
Good Luck,
bt
Old 02-15-2020, 05:46 AM
dataway's Avatar
Yeah, I've read some stuff about power transistor matching being important... the pre-amp and power amp need to be matched.
At this point, I'd be about $50 and several hours to fix the stuff I've found. What's bothering me is I get nothing out of the head phone jack which should be before any of the power amp circuitry ... I think. FM tuner scans but doesn't find anything.
I can buy a functioning unit for $50 on ebay.
Damn this weird urge to fix old things.
Old 02-15-2020, 07:46 AM
Old Goat 67's Avatar
Think of it as just being the dominate part of your DNA.
