Old 05-14-2020, 08:40 PM
topfuel67 topfuel67 is offline
Default Correct color for propeller shaft
Was it bare metal or black from the factory? I saw the post from April and am going to do the stripes (my 66 shop manual confirmed the correct colors for the 4 speed stripes). I just media blasted mine and am ready to either clear coat it or paint it black. Thanks in advance.
Old 05-14-2020, 08:50 PM
Keith Seymore's Avatar
Bare.
A little bit of chassis black overspray might have gotten on one side of it while they were spraying some of the other assembled chassis components.
K
'63 LeMans Convertible
'63 Grand Prix
Old 05-14-2020, 11:22 PM
Thank you for the reply.
Old 05-15-2020, 08:11 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
I would not clear it. Anything I have cleared over the years always rusted back in short order. I would either paint it in cast paint or use some of the 'rub' on stuff that is on the market. This is what a lot of restorers use on their concours restorations. It works good for front suspension items such as sway bar, tie rod ends, etc.
Maybe someone else will know and post a link for that product.
Old 05-16-2020, 05:57 PM
I used cast color spray paint on a few things like the sway bar. I don't know if that paint will prevent rust any better than clear, except maybe it will hide it since it is color. I ended up just spraying clear on it. I media blated it several times with crushed glass, then sanded with 100, then sanded with 220, cleaned and sprayed clear. I figure I'll spray the stripes on and use a brush to give them a brushed on appearance. I'm guessing the drive shaft manufacturer applied the stripe with a brush while it was on a lathe.
Old 05-16-2020, 06:58 PM
That is correct (actually, while the shaft was on the balancer. After the balancing operation was complete the operator would turn the shaft by hand while holding the paintbrush).
K
'63 Grand Prix
Old 06-06-2020, 02:26 AM
I ended up painting it cast color and then added stripes. I had to get a new propeller shaft as the end was not straight on the other one. Luckily I found one local in So California that has been in a garage since the 60s. Perfectly straight, no dings, scrapes, etc.
