Just to add some data here, I have 2 ,1976 wx code 455 blocks, originally from a 4speed t/a. One std bore, one.030 and needing a rebore. Both are 2 bolt main caps, both blocks only drilled for 2bolts. had the .030 block sonic'd, all bores, 4 places at top and half way down cyls. Thinnest spot was 0.168" .
Block is WA std. bore. Drilled for 4 bolt, but with 2 bolt caps. What's odd is my literature say a WA block was only produce for the 70 model year, and denotes 4 bolt caps. Is this right?
Thanks, for the info. |
The engine I am doing now was hard blocked with a tq plate and cured for months with it on, each side then bored. Dan said it all mattered for ring seal. |
I have stacks of garden variety standard 455s from big cars ranging from 70-76 and one 455HO, only the HO has 4 bolts but all the others are 2 bolts but drilled for 4 bolts.
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘22 Toyota Sequoia V8 ‘23 Lexus LS500 awd ‘95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
All the 1970 455's with #64 Heads i have encountered were 4-bolt Mains. Whether GTO , Bonneville or GrandPrix All have been Automatic Codes YA, YC, XF Never had a manual code I am surprised some others have had these that were 2-Bolt Mains. But evidently they are out there. All the YH with #15 Heads i have known were all 2-Bolt Mains Very Very surprised your friends WA Block is 2-Bolt Mains He should have the align bores checked to offer peace of mind to a buyer. It's a hard code to find usually, and most will expect 4-Bolt Mains. So its a tuffy |
The only time you will find a 455 that started life as a 2 BBL motor will be if the assembly line ran out of the two bolt blocks and had to dig into there 4 bolt stock , as this has happened!
Also what has been seen is the the same thing with a dealers warranty repair on a 455 or any Pontiac motor that could have come with 4 bolt mains, but this sonareo is extremely rare.
Not sure what you are trying to say? Do you mean that all 455 2BBL engines NORMALLY would have had 2-bolt mains, except if the assembly line was out of those blocks? That seems plausible and reasonable. FWIW, Bob Maxey preferred undrilled 2-bolt main blocks for his highest horsepower builds. Yes, he stayed with the 2-bolt main caps. Stuart |
Dragncar
A fwiw, the fellow that sonic tested that 455 block stated a minimum of 0.125" on the thrust side. Those measurements I mentioned again were on the front side of the cylinders, why they were thinner than other areas I have no idea. On the inside and outsides there were many well over 0.210". ...... .0214, 0.218, 0.229, 0.230, .0232 ,0.229, 0.240...etc, etc. Side note.. The best block filler is Race Engineering "Block Rock". Good product and is a easy material to work with. Fast setup time and the block is machinable in 24 hours. Plus they claim it will not crack or separate with age. .
I have 70 XF 455 4 bolt with 4 bolt caps and 64s
This 9 sec. 65 Catalina runs a punched out 455 4 Bolt main Block > Also NUNZI Mentioned he even used 2 Bolt main 455 Blocks as a starting point for some of his Blown applications - less distortions etc.
The Bandit Rules - Make mine with a SD-455 Engine . |
Here's one NUNZI Wrenched on 1975 T/A Blown 455 > 800 hp > Really woke up those New York Neighborhoods - Brooklyn etc.
