View Poll Results: '66 or '67 GTO, which do you like best?
1966 109 46.58%
1967 125 53.42%
Voters: 234. You may not vote on this poll
Old 04-21-2016, 11:45 PM
Default '66 or '67 GTO, which do you like best?
Which one do you like best?
We're only choosing between the '66 and '67 GTOs here.
Give your reasons if you like, but be sure to vote!
Old 04-22-2016, 12:49 AM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
I actually like the 65 the most but since you limited your poll to 66-67 I went with 67 because I have one! Why did you limit the choices?
Old 04-22-2016, 12:57 AM
Mark D's Avatar
Mark D Mark D is offline
Love the grills, tail lights, opportunity to get a T400 & a Hurst Dual Gate in automatics, standard steering wheel, Rally II's, and even the vertical piping on the seats....Not to mention I was born that year.
Would love a hardtop in Burgundy or Tyrol Blue.
1966 GTO, SD Performance MR1 535, 784 hp.
1967 GTO Convertible, 77k Survivor, 18 Options.
1968 GTO, 1 Owner, Endura Delete, 1 of 1.
1970 GTO JUDGE, 57k Survivor, Ram Air III, M20.
1970 TRANS AM, Ram Air III, M20, Norwood, 10 / 201.
Old 04-22-2016, 01:32 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
I'm like Phil, actually like the 65 the best. Second though from the 64-67 is the 66. Don't get me wrong, I do like the 67 just like the 66 better. Years ago I didn't like the 67 grill or tail lights nor did I care for the wide trim at the bottom with the small GTO crest, but now I'm starting to like it more and more. Funny how your taste change over the years.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 04-22-2016, 08:08 AM
Sloan66's Avatar
Sloan66 Sloan66 is offline
65 will always have a soft spot in my heart, first car was a 65 Tempest, but totally fell in love with the 66. Best taillights ever! I think more design work went into the 66 especially the rear of car. Was never a fan of wire mess grill on 67, or the vinyl inlays on dash and console. The real wood on 66 I think looks better.
Old 04-22-2016, 08:23 AM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
67 obviously. Prefer the wide lower trim and the rear tail lights. Along with the mesh grille.
On the inside the wood grain console and the hazard flasher on the column. The dual Gate shifter is a great touch as well along with the Turbo 400 transmission. Also the 67 dash trim pad is much cleaner looking than a 66. A 66 would be second choice.
Scott
If you always do what you always did
You always get what you always got
Old 04-22-2016, 08:34 AM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
Love:
Grilles
Tail Lights
400cu
Wide lower side trim
Just so much..... wanted one since I was 13.....
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
Old 04-22-2016, 10:26 AM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
The 1966 GTO has always been my favorite, but I like all Pontiacs.
I really like 66 GTO's in Bright red and Squeezed lime green. (lol....)
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph
Old 04-22-2016, 11:07 AM
Because the focus of this sub-forum is on '66 & '67 cars.
There's another poll in the '64 & '65 forum as well.
Old 04-22-2016, 12:11 PM
Tempest's Avatar
Tempest Tempest is offline
love the 66 tail lights and rear eye brows, but must vote 67.
The 67 mesh grills with eye brows, the availability of the TH400 trans, the Rally 2's, the 3 spoke steering wheel, and the vertical stitching on the seats, all favour 67.
Old 04-22-2016, 12:40 PM
Satyr1966's Avatar
Satyr1966 Satyr1966 is offline
I don't know how many responding have owned both, but I have. They are the only year GTOs I have owned & are my #1 & #2 favorites without a doubt. Both years have strengths and weaknesses. The '66s strengths are as follows. Last year for the Tri-Power & the 389. You gotta love a 389 Tri-Power. The rear end on the car is gorgeous, I love everything about it, especially the louvered tail lights. The real wood dash. The full dash pad. The metal window crank knobs. I know the next two items are a matter of personal taste so let me just say that I personally think that both the rocker panel chrome & the overall front end look better on the '66. As far as the weaknesses go, The two speed automatic stinks. No disk brake option & that's about it. The '67s strengths are first & foremost, the Turbo 400 with the dual gate. Available disk brakes. The 400 has 11 more cubic inches and better flowing heads than the 389. I love the wire grill inserts although I still like the 66s overall front end better. The '67s main weakness is that the tail-light panels all rust out. For me this is a very close call & if you want an automatic car I would recommend you get a '67 or get a 66 & put in a Turbo 400 & a dual gate. If you want a four speed I would recommend the '66 every time. Just my 2 cents worth. Jerry.
By diligent effort I seem to be prolonging my adolescence to total absurdity. John D. MacDonald
Old 04-22-2016, 01:36 PM
tripower's Avatar
tripower tripower is offline
Tough one but voted 66 because of the Tripower WS plant over the 400. Bow tie look of the 66 just look sweet!
Norm J
Old 04-22-2016, 04:08 PM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
66 has the coolest tail lights in the industry.
67 has better grills, rocker moldings and you could get a hood tach. And if you must have an automatic... that dual gate!
I still prefer 66. Those tail light bezels.
Mitch Kunath
Old 04-22-2016, 05:52 PM
gtospieg gtospieg is offline
'67 for me...taillights, grills..just like them better but wouldn't say no to any GTO
Old 04-22-2016, 06:10 PM
gtorich gtorich is offline
I totally agree with goatmanmitch...........I have a 66, but if they put that rocker molding & grills of a 67 on the 66, that would be one good looking ride.
Rich
Old 04-22-2016, 07:03 PM
roy381 roy381 is offline
Put those 66 tail lights on my Tyrol blue 67 I'm a happy man!
Old 04-22-2016, 07:13 PM
To me this is the toughest choice of the three 'which one' threads going right now. I have to give the slight edge to the '66 because of the tripower availability and the tail lights.
Tough choice though as they both have that wonderful coke-bottle body and the best stacked headlights of any car, ever....even the '65 is not as nice in the headlight/grille area..
Old 04-22-2016, 07:26 PM
SR-71 SR-71 is offline
I never cared much for the 67s since it seemed like in retrospect it was the beginning of the bolt on parts like body cladding in the 80s. I thought the 67s looked like Pontiac didn't want to spend the money on changing the body style so they starting bolting parts on. Wide stainless rockers, wire mesh grilles, saved money on not making the complicated taillights from 66 and went to plastic wood. They spent money on disc brakes and a good automatic those are huge pluses. I still wouldn't turn down a nice 67 but my preference is the 66.
Old 04-22-2016, 10:38 PM
goatman65's Avatar
66. I grew up with this one. My parents bought it new. This pic is from last fall,still unrestored. Spent a lot of time in the backseat with Hot Wheels.
I do like the 67 grilles better.
Old 04-23-2016, 12:45 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default 1966
The 67 GTO with the HO is awesome but,
I still like the old 389, plus it's the last year you could order the three deuces!
Old steering column.
Old style inside rear view mirror (no rubber)
Only year for the real wood on the instrument panel.
1966 is my choice, but not by much.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
