Old 04-13-2020, 03:50 PM
1969 Ram Air 1969 Ram Air is offline
Default Intake Identification
The attached aluminum intake came off a '70 ram air IV engine. The cross over has a part number and date code and it appears correct, but the intake is missing a part number and a date code. Can anyone help identify it?
Thanks.
ID:	537217   Click image for larger version
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
Old 04-13-2020, 03:57 PM
Default Pic
Pic.
Old 04-13-2020, 05:40 PM
thepontiacman's Avatar
Is there anything on the bottom of the intake?
Old 04-13-2020, 06:41 PM
Default Intake
"Is there anything on the bottom of the intake?"
No. It's bare.
Old 04-13-2020, 08:02 PM
Strange
Old 04-13-2020, 08:09 PM
"Strange".
That's exactly what Potokar said.
Old 04-13-2020, 08:57 PM
No Winters / Snowflake trademarks either.
Moderators should remove this thread
Intake goes against anything we can fathom.
Must be a proto-type for the 69 unit , that snuck out of engineering dept.
Old 04-13-2020, 09:38 PM
tom s tom s is offline
Is there anything on that little pad between the GM3 and the 2?The factory sometimes would put a change number on there if it was a engineering piece.Tom
Old 04-14-2020, 11:59 AM
There are no numbers on the little pad.(see pic) There is a "3" stamped near the front.
ID:	537300   Click image for larger version
Old 04-14-2020, 12:02 PM
Uncle Judge's Avatar
Uncle Judge Uncle Judge is offline
I actually believe that is a pre-production piece. Especially with the GM 3 cast into it just like a cast iron intake. And no Winter’s logo. Even the part number blank is in an entirely different area.
A very strange piece indeed. I absolutely believe it is a GM part and not a reproduction though.
Old 04-14-2020, 12:08 PM
Region Warrior's Avatar
The 9796395 crossover was used on 69 and 70 RAVI.
Old 04-14-2020, 12:22 PM
The casting quality is pretty hairy. Hairy enough for only a proto-type.
I think the cross-over with an April 1970 date/part # is just something that joined up with it later on much after the fact.
Intake has been around the block several times it appears.
It's a really cool piece to see
Thanks for sharing it with us !
Probably deserves its own self-titled thread
And see if anyone else ever discovers or has one.
Where did you pick it up , and how long have you had it ?
Old 04-14-2020, 12:33 PM
If the Intake Ports and Bolt Holes aren't heavily reworked - then its factory.
As in how flush a factory gasket would match up.
If they have been whacked up a lot and look oddbally -
I suppose there might be chance it was a proto-type for the repop job.
Much cooler if it looks mostly or completely untouched in reference to ports and bolt holes.
Old 04-14-2020, 12:53 PM
Thank for all the comments.
I bought it recently from a guy with a RAIV '70 Judge who installed fuel injection on the car.
I will post some pics of the ports.
Old 04-14-2020, 02:04 PM
Kenth's Avatar
Kenth Kenth is offline
I´m sure you ment 69 and 70 RAIV.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 04-14-2020, 03:00 PM
Port pics
ID:	537307   Click image for larger version
ID:	537308   Click image for larger version
ID:	537309   Click image for larger version
Old 04-14-2020, 04:57 PM
Its a Factory Proto-Type
For all we know - they may have even wanted this type intake on a 68 Ram2.
It probably goes that far back into actual round port history / development.
(that's just my own thought)
The ports have had some hand tooling (some more than others)
And it looks like most was done on a rookies workbench in a rush.
This could have been flash removal, or gasket matching from a Ram2 Intake Port - to a Ram4 Intake port.
either or both
A couple bolt holes have the rookie touch too.
Possibly to coax fitment with some shaved heads in the past.
But its not wild enough or good enough that it was done to fit a PartsPlace Re-Pop type intake.
Supposedly they take a lot of good work to be proper.
Or a lot of ugly bad work, and they still look wonky on the port divider margins when its all said and done.
If not epoxied or welded to get the divider margins back in tune.
The thermostat gasket surface area and perimeter look nothing like the Re-Pops either.
They are fatter/wider/blubbier and have a much different contour around the thermostat bolt hole zones .
And it seems to have too much age/mileage/use to be very new (repop proto-type)
That's my 12cents
Old 04-14-2020, 05:51 PM
BVZ - Thank you for your excellent analysis. You really know your intakes. I am glad it is not a repop!
Old 04-14-2020, 06:44 PM
Someone would have to hold it in their hands and take a real mean look at it to see if it might have originally had Standard/Ram2 intake port openings.
That would be pretty F'ing awesome if it did.
No matter, either way, its a neat piece of our history you have there.
thanks again for sharing it with us
Old 04-14-2020, 08:32 PM
tekuhn tekuhn is offline
Hard to believe the person you bought it from would not want to hang on to all his original parts 😳, but good for you!
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures
