Old 06-14-2020, 07:24 AM
Tomaso Tomaso is offline
Default 1966 Bonneville fuel tank?
Hi all,
I'm looking for a fuel tank for the Bonneville but I am In Canada. No Canadian vendor I have called has them or makes them.
Now, I know several from the US that do have them, however they're asking for about 600Usd just to ship to Canada. Not including the cost of the tank.
I am just wondering if there is any other tank that would fit or work??
Thanks,
Mike
Mike
Old 06-14-2020, 09:25 AM
389 389 is offline
How about having the original coated?
Old 06-14-2020, 10:30 AM
That's what I was thinking. But how good are the coatings? (The tank leaks).
Mike
Old 06-14-2020, 12:14 PM
Sirrotica's Avatar
As close as you are to Buffalo, couldn't you drive/trailer the car to a shop in Buffalo, and have a tank installed in it? No duty hassle going back if you don't have a tank by itself.
Just a thought, maybe it wouldn't work for you?...........
The coatings are as good as the person installing them, the labor/experience is the main ingredient, the coatings have been around quite awhile so they're perfected.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-14-2020, 12:42 PM
AZ64GP AZ64GP is offline
Have you thought about having the gas tank repaired? You said it leaks, but I had a small hole in my original tank in my '64 GP which I had repaired. I found a small repair shop locally which also repairs radiators. They welded the hole in the tank to close it, and then I used a gas tank sealing kit that cleaned and sealed the tank from the inside. I've also heard of people repairing small holes in gas tanks with special epoxy kits. After I had my tank welded, I had the tank powder coated in silver (I did this before I sealed the inside), and it completely obscured the weld repair...it looks like a new gas tank from the outside.
I think between the weld repair, the powder coating and the sealing kit cost, I spent about $250 (US). This was before my gas tank was repop'd so I didn't have the option, but doing that may be way cheaper than spending several hundred dollars to replace your tank.
Old 06-14-2020, 12:46 PM
Yes. Actually. It's a radiator shop as well and local and has good reviews. I may just leave the tank with him. I was just worried about the coatings and repairs.
Didnt know if I should fully trust gas tank repairs versus just buying a new one. So I may do that.
The only thing I would need though and cant seem to find online for some reason? The new fuel tank straps? Any ideas on who has them?
Mike
Old 06-14-2020, 06:04 PM
I was able to take my old gas tank straps and have them media blasted and powder coated. As good as new. I also bought the rubber pieces for isolation and bought new hardware for the straps. I believe our Host sells reproduction gas tank straps and hardware, but if not, I've seen them sold elsewhere online.
