Old 02-13-2020, 04:38 PM
Mike,
The air cleaner does have the studs. The metal pieces that the studs are attached to are both bent. It looks like someone tried to pull the air cleaner off the engine without removing the wing nuts from the studs. Easy fix, I just haven't gotten around to fixing it yet.
Thanks Chris,
Did the air cleaner have studs? Brackets?
Name:	RA air cleaner.jpg
  #42
Old 02-13-2020, 04:52 PM
Dennis,
More pictures....
Chris...you do know we are going to need to post more pictures...and lots of them.
Dennis
ID:	531826   Click image for larger version
Name:	Both cars 2.jpg
  #43
Old 02-13-2020, 06:05 PM
napster's Avatar
napster napster is offline
Originally Posted by eaglesan13 View Post
Dennis,
More pictures....
Love both of these pictures.
  #44
SD455DJ SD455DJ is offline
Dennis,
More pictures....
Sweet Chris....now more! It looks like your hood doesn't have the dreaded 'bow' in it and sits nice and flat.
Did you get the 3.73 gears with the car, or are they long gone?
Dennis
  #45
Old 02-13-2020, 09:46 PM
Bentwheelbob's Avatar
I agree. The pictures and hood look great. My advice is to leave the hood unlatched during garage storage. I look forward to more.
  #46
Old 02-14-2020, 01:46 AM
The hood is in nice shape and fits very well. I did not get the 3.73 gears with the car. I still need to call the guy in Long Beach Washington to talk to him about his ownership of the car. Maybe I'll get lucky and he will have the old gears (and starter).
...It looks like your hood doesn't have the dreaded 'bow' in it and sits nice and flat.
Dennis
ID:	531879   Click image for larger version
ID:	531880   Click image for larger version
ID:	531881   Click image for larger version
  #47
Old 02-14-2020, 01:49 AM
More hood pictures. The underside picture shows that there is no metal brace, so this is an early (1970 style) hood, which surprised me since I do not consider this an "early" car. It has the early 524 and 525 hood hinges too. I then looked at the hinges on my trans am and they're the early hinges too.
ID:	531883   Click image for larger version
ID:	531884   Click image for larger version
ID:	531885   Click image for larger version
  #48
Old 02-14-2020, 08:02 AM
Chris, Bob (BWB) offers sage advice to keep the hood unlatched (while in the garage - lol), especially for your early unbraced hood. Can't wait to see more detail pictures as you give it a thorough examination. It seems to be very complete and original...amazing after 49 years!
Dennis
  #49
Old 02-14-2020, 09:15 AM
Very interesting !
  #50
Old 02-14-2020, 05:44 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Mike,
The hard fix will be replacing the missing hose clips.
So long, farewell.
  #51
Old 02-14-2020, 10:09 PM
Dennis
Guys, the hinges "pushing up" on the hood (or latch pulling down...) are not what caused these hoods to bow. Don't subscribe to the unfounded "internet wisdom".
The kinematics of the hinge are such that it's not exerting rotational/upward force in the fully closed position.
I can take the latch and anti-chuck spring out of mine, and the hood just sits on the bumpers. In the fully down position, the hood hinges are collapsed to a point that they don't have enough mechanical advantage to rotate the hood up. When you pop the latch, it's the anti-chuck spring that lifts the hood. The higher you lift the hood, the MORE force the hinges are able to impart on it. That's why it actually get easier to lift the hood as it raises up.
Popping the hood up off the latch would be worse for two reasons:
1) the hood hinge spring exerts more force as the hinge opens
2) the front corners of the hood are unsupported when it's up on the latch
This car's hood still looks good after 50 years of being latched.... that says something.
  #52
Old 02-16-2020, 01:58 AM
It's actually not too hard to replace those clips. They were missing on the trans am air cleaner when I got that car. I went out to the local Pick and Pull and found a couple of old GM air cleaners and used a putty knife and hammer to knock the clips off, then tack welded them onto my air cleaner.
  #53
Old 02-16-2020, 12:11 PM
tahosdra tahosdra is offline
Default straight line racing
Hi Eaglesan , just wanted to let you know This shop is still around. The owners name is Andy Rankin. He works on muscle cars and hi perf boats . Also a drag racer.
  #54
Old 02-16-2020, 12:42 PM
FASTASSBIRD FASTASSBIRD is offline
Van Nuys car or Norwood?
  #55
Old 02-16-2020, 01:48 PM
Thanks for the info.
  #56
Norwood.
  #57
Old 02-16-2020, 01:52 PM
Dash and gauge pictures.
ID:	532100   Click image for larger version
ID:	532101   Click image for larger version
ID:	532103   Click image for larger version
ID:	532104   Click image for larger version
The Following User Says Thank You to eaglesan13 For This Useful Post:
  #58
Old 02-16-2020, 01:54 PM
More interior pictures. The bucket seats have been recovered, but the rest of the interior is original.
ID:	532106   Click image for larger version
ID:	532108   Click image for larger version
ID:	532109   Click image for larger version
ID:	532110   Click image for larger version
Name:	Interior.rear seat 1.jpg
  #59
Old 02-16-2020, 02:47 PM
Judge273's Avatar
Judge273 Judge273 is offline
When you get a chance....engine shots. Please.
Mike/Illinois
  #60
Old 02-16-2020, 03:05 PM
Brewster's Avatar
Brewster Brewster is offline
