Oil Pan gasket
What pan gaskets are you guys using ? I will have a aftermarket Steffs pan.
My friend has had great luck with no gasket, just silicone. I will be using The Right Stuff per Steffs instructions. I was thinking about no gasket and the cork gasket that goes over the rear main cap. I don't think the Steffs pan has the holes for the tabs at rear main anyway. |
Cork ..
My Half AN Injun..... |
I like the 1 piece from Butler. Very nice and leak free. I simply use a little "Right Stuff" in the corners.
Butler one piece here also, had it off and back on three times and still no leaks.
BOP Engineering 1-piece gasket...same one sold by Butler made by BOP Engineering: https://www.bopengineering.com/beltd...c_topend.shtml
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
the bop gasket is great on factory blocks and maybe MR1 they will not work on an IA2
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
They work on the MR1, that's what dad is running on his.
Does the BOP have the rear main tabs. My pan does not have the holes.(Steffs)
Why not on the IA-II?
This is what I am dealing with. Thinking cork contact cemented to rear cap and The Right Stuff between it and pan.
Yes, 5 tabs so you cut off what you don't need. The section with tabs is rubber so I'd be concerned it would squish out using a pan without the corresponding holes. I read somewhere where someone cut that section completely off and just used the cork over the rear main with a pan like yours. Personally, I would just use the regular pan gasket at that point.
IA2 block has a .125 lip for a registered fit main cap. So it will need a taller rear gasket or a custom(silicone) adjustment.
I am sure others will disagree, but I would not use Right Stuff by itself as an oil pan gasket on a fabricated pan. I am surprised Steff's would recommend Right Stuff as a gasket replacement. If you ever need to remove the pan, you will probably have to replace it. That stuff dries so hard, I don't know how you would separate it from the block without bending and damaging the pan. I guess an alternative might be to drill and tap the pan rail for 4 jack screws to push the pan off the block if you ever need to remove it. We used soft setting RTV, not right stuff by itself with all our fabricated pans. No leaks and no issues. Specifically, Valco brand. But 3M or Permatex is similar.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
That is very possible. I didn't realize they eliminated corner bolt holes. The Moroso 2 piece pans we use have some side pan rail bolt holes eliminated but the 4 corner bolt holes are retained. Looks like they did compensate for that with the very thick and rigid pan rail pieces. They look 30-50% thicker than the Moroso pan rail pieces. Happy with the fit of the Moroso pan, however, no bashing.
Here are some pics. There is a thread on it in the race section but its more of a race pan. Big kickout and trap doors, fits in a stock frame though.
Nice looking pan. Are there bolts for the timing cover ???
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
This pan actually gives you horsepower vs just having a aftermarket pan for oiling issues. It does both. 10-15 HP, maybe 20 on a big engine you spin high. The kickout and scrapper with windage screen gets more oil off the crank vs a standard scrapper that scrapes the oil off the crank only to go down the side of the pan. Canton makes one that does the same thing but its kinda ugly and they could not make me one due to Covid. |
Looks like a nice pan. The area between the front most side bolt holes and the timing case 2 bolt holes is a long span as you mentioned. I don't see any issue in the back with the missing bolt holes. that front span is probably 8-9 inches? on each side.
