Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 08-03-2020, 11:15 AM
Va68goat's Avatar
Va68goat Va68goat is offline
Default GARAGE SALE
Feel free to make an offer. I don't “need” to sell these items but I would like to free up some space in my garage. Shipping covered by buyer from 20112 (Manassas, Virginia)
See photos
- 68 GTO dash gauge housing (Original - radio cut): $100.00
- 68 GTO dash pad (original - could use new cover but not bad): $135.00
- 68 Deluxe steering wheel (needs restoration but not bad at all): $175.00
- 1971 455 block (YG code / Date code: E241) Standard bore, hot tanked and mag tested (I have receipt from the machine shop that tested the block): Lowered price from previous post to: $700.00
- 6X heads: Heads are bare: $100.00 (Buy the block and heads together ($750)
- 400 crankshaft: standard / needs machined: $100.00
The below items will be up for sale soon: Contact me for additional information.
- Turbo 400 transmission built by Jim Hostler of Hostler Transmission: Built to handle 650 HP: Less than 600 miles on transmission. (Will be up for sale once I install the 4L80E in a few months).
- 2500-2800 stall converter done by Cliff Ruggles: (Will be up for sale once I install the 4L80E in a few months). Less than 600 miles on converter.
- Original 1968 GTO gauges with circuit board: (Will be up for sale once I install the new Dakota Digital gauges that should arrive in about 6 weeks. (These gauges are not reproduced).
- Drive shaft (currently on my 68 GTO). Balanced less than 600 miles ago.
- Power antenna for 68 GTO: Needs to be reconditioned but in good condition. (I'm still researching value but if anyone has an idea, please let me know.
Feel free to make an offer on the items with a price. Contact me if you're interested in the Turbo 400, converter, gauges, drive shaft or power antenna.
Joe
ID:	546356   Click image for larger version
Name:	455 block - 6X heads - 1.jpg
ID:	546357   Click image for larger version
Name:	455 block - 6X heads - 2.jpg
ID:	546358   Click image for larger version
ID:	546359   Click image for larger version
Old 08-03-2020, 02:27 PM
77 TRASHCAN's Avatar
Sent you a PM
Shut it off
Shut it off
Old 08-03-2020, 06:21 PM
Va68goat's Avatar
77 TRASHCAN (Jeff)
Good talking to you. Check your email. I sent you the build sheet for the converter. I'll reach out to you as soon as we have a date to swap out the trans.
Old 08-17-2020, 07:48 PM
Va68goat's Avatar
Default UPDATED LIST
- 68 GTO dash gauge housing (Original - radio cut): $100.00 **MAKE OFFER**
- 68 GTO dash pad (original - could use new cover but not bad): $135.00 **MAKE OFFER**
- 68 Deluxe steering wheel (needs restoration but not bad at all): $175.00 (MAKE OFFER)
- 1971 455 block (YG code / Date code: E241) Standard bore, hot tanked and mag tested (I have receipt from the machine shop that tested the block): Lowered price from previous post to: **SOLD**
- 6X heads: Heads are bare: **SOLD**
- 400 crankshaft: standard / needs machined: $100.00 ** MAKE OFFER**
- Turbo 400 transmission built by Jim Hostler of Hostler Transmission: Built to handle 650 HP: Less than 600 miles on transmission. (Will be up for sale once I install the 4L80E in a few months). ** May be spoken for**
- 2500-2800 stall converter done by Cliff Ruggles: (Will be up for sale once I install the 4L80E in a few months). Less than 600 miles on converter. **May be spoken for**
- Original 1968 GTO gauges with circuit board: (Will be up for sale once I install the new Dakota Digital gauges that should arrive in about 6 weeks. (These gauges are not reproduced). ** MAKE OFFER**
- Drive shaft (currently on my 68 GTO). Balanced less than 600 miles ago. ** May be spoken for**
- Power antenna for 68 GTO: Needs to be reconditioned but in good condition. **SOLD**
Contact me if you're interested in any of the available or soon to be available items.
Old 08-18-2020, 08:34 AM
Half-Inch Stud's Avatar
Good luck with the 4L80 hookup.
