Old 08-08-2020, 05:08 PM
slowbird's Avatar
slowbird slowbird is offline
Default Just for fun, camming big head
Just for fun/discussion, how would you guys cam a 11:1 pump gas street/strip 461ci with edelbrock wide port heads that flow 360-370cfm. I have my ideas just wondering what others think and why you think it.
And last but not least, would it be a dog no matter the cam used?
Old 08-08-2020, 05:15 PM
Steve C. Steve C. is offline
Can we not presume one deciding factor could or would be at what rpm would you want the combination to make peak power at ?
Also I will presume on such a head that cfm flow is probably rated at 0.700" lift or higher. Many would suggest the cam should be designed for maximum lift to take advantage of that.
Old information here:
Old 08-08-2020, 05:19 PM
slowbird's Avatar
6800rpm sound good?
Old 08-08-2020, 05:26 PM
pastry_chef's Avatar
I'd prefer KRE high ports over E wide ports.
For this example we don't know CSA, throat size but I'd guess a bit higher than 6800 RPM. Maybe 7200 RPM or so.
Old 08-08-2020, 05:30 PM
slowbird's Avatar
What cam and why.
A Butler wide port has a mcsa of around 3.35-3.4
Old 08-08-2020, 05:36 PM
To further muddy the water, what Combustion chamber design ? The old style or the revised CNC design that will allow more compression and can influence the cam design.
Old 08-08-2020, 05:38 PM
slowbird's Avatar
I set compression at 11:1 in first post.
You really think there is that big of difference in the two designs? Maybe there is??
Old 08-08-2020, 05:50 PM
Since this is in the street section I'm presuming the use of pump gas in this conversation. The chamber design has some affect on the situation if you want to push the envelope. To some 11:1 would be doing so.
( Side note, and only to serve as an example. Regarding Edelbrock heads and the older design chamber you can run more compression with the 72cc chamber vs the 87cc chamber because of the slight difference in design. But here that's a moot point because the obvious these heads would not start out with 87cc castings )
Old 08-08-2020, 05:52 PM
A starting intake lobe would probably be something like:
Comp HXL
2233 303 274 197 .454
2234 305 276 199 .454
1.7 or 1.75 rocker if I could.
Old 08-08-2020, 06:25 PM
slowbird's Avatar
Comp HXL
That's a pretty good sized lobe for a 11:1 461 street/race engine
Old 08-08-2020, 06:28 PM
JLMounce JLMounce is offline
This engine sounds pretty similar in build to an LSX 454. It’s not an apple to apple comparison of course with the lsx head flowing around 370cfm at .700 and having a more efficient port. That said, I believe that engine runs a cam in the 236/247 range with 1.8 ratio rockets. Lift is close around .65 with a 1.8 rocker.
I’d think something in the 240/250 range might be a good place to start looking.
-Jason
1969 Pontiac Firebird
Old 08-08-2020, 06:40 PM
Stated .... "That's a pretty good sized lobe for a 11:1 461 street/race engine
Yes, but your tossing out wicked peak power RPM numbers for a 'street car' !
I ran a UltraDyne sold roller with 279/287 at .050 with a 110 lobe separation.
It made peak power at 6900/7000 rpm on the dyno. 'Bigger' than the cam pastry_chef mentions. BUT not apples-to-apples, my engine had a shorter 4.125 stroke. Also, and important, the Edelbrock heads had a much smaller 236cc intake runner volume.
( TH400 transmission with manual valve body and a 8-inch Hughes Performance converter. 3.73 to 4.30 gears. 28" tires and a 4675 lb race weight. The Edelbrock heads had 11.2 compression with the older design chamber. At the track we ran 105-octane race gas. It was limited street driven but I had to add race gas in with 93 octane pump gas. 10.36 at 129 mph on the motor and 9.59 at 140 mph with a single nitrous plate )
Old 08-08-2020, 06:50 PM
Yes.
Well aligned to the oversize head.
Old 08-08-2020, 06:53 PM
LSX454 makes peak power at 6300 RPM.
An E-wideport / CSA on a Pontiac 461 only peaking at 6300 RPM will be a lazy dog.
Old 08-08-2020, 06:56 PM
slowbird's Avatar
Yes.
I made peak power from a 496 and 11:1 at 7200rpm with the second lobe option. Putting that in a 461 should peak well into the mid 7000rpm range or higher imo.
I like JLMounce recommendation
Old 08-08-2020, 07:08 PM
Your 496 ran a much better head/intake. And peaked exactly where my math says it would.
Another Brian more than 10 years ago ran a 11:1 461 - Butler E-wideport with Victor, 272 / 280 @ .050 and it peaked at 6900 RPM. Less lift . 440 lobe.
Old 08-08-2020, 07:24 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I do know what cam will work best but I won't tell you... Fwiw
Go fast, see Elvis!
Old 08-08-2020, 07:32 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Solid roller or Hyd roller?
Old 08-08-2020, 08:59 PM
slowbird's Avatar
Why were my heads better and it was just a ported Victor so intake doesn't matter.
Did that other Brian dyno? I remember that combo but didn't think he dyno'd
Old 08-08-2020, 09:17 PM
slowbird's Avatar
I sure would think if bigger heads/intake would be run on this engine the rpm peak would be pushed up. So a smaller cam would be needed.
The other thing that's not been discussed is valve events (tighter LS or wider, LC advanced or retarded) that will make a pretty big difference.
Thread Tools
Display Modes
