#41
But the OF cam might work pretty darn good in this case |
The Following User Says Thank You to slowbird For This Useful Post: | ||
#42
The other is duration at .006 or .020 just doesn't give much info. Two cams can have the same .006 duration but be wildly different. If .006/.020 and .050 was giving it would be more useful imo (adding .200 duration would be even better). Thanks for sharing |
#43
I can tell you that's absolutely not the case at all. Cracks me up when Pontiac people think even out of the box Edelbrock runner size is too big, lol. Everyone back in the day when I bought those heads (nearly 20 years ago) told me they were way too big for my engine. I bought them anyway knowing I was going to build something bigger in the future. Here I am today still driving this combo. I put a very small hydraulic roller 242/248 @ .050 cam in it with about .640 lift, on a 110 lsa. I installed it at 106. 10.2:1 compression. Runs 91 pump. Makes just a smidge over 600hp and almost right at 600 tq. The throttle response is ridiculously quick, there is no lack of power anywhere in the curve. I drive it on the street 99% of the time, and it sees the track maybe once a year for fun. It's an excellent combo that can be daily driven easily, makes excellent vacuum at idle, works the power brakes, and MPG really isn't that bad either. If it were more race than street I would have certainly put more cam in it and looked for bigger HP numbers. The heads will certainly support it. My plan now is to put these heads on the 509 with a little more cam, pump gas compression and make close to 700hp. Of course even today people say that's the biggest head they would recommend on a 509. I just laugh, that's utterly ridiculous. In a nut shell, I prefer to build with an excellent head and then use a smallish cam rather than the other way around. |
#44
#45
The program does include a database of cams. I just have not added all that should be there. This is the only one that somewhat fits. But it does need some big rocker arm ratios to meet the recommended valve lift. Stan
#46
Cool! But ya that's a serious ratio
#47
Maybe SD cams Road Paver with 1.8 rockers is the ticket?
#48
Ok, it matters but whatever. "pretty well", not for the money you spent IMO.
#49
Also just what happens when the port stalls and you run more lift? The heads on our 400 stall at .500 but we're running .600 lift. Would it be faster if we ran less lift? Leech's heads stalled/backed up also maybe he would've gone faster if he didn't run .950lift?? How much did i spend? Any na pump gas car faster? Im sure you'll open eyes with your amazing pump gas build (assuming you don't window it again). |
#50
Your BBC makes great power for a 242/ 248 cam. I do not know of any Pontiacs getting that (600-600) done with such small a cam. Cam-ing a engine is about keeping the air accelerating so you can accelerate the car. And that does not mean max lift-max cfm. |
#51
Not sure what Mikes engine has to do with this, it was 18 to freaking ONE. Changes things right ? What I am saying, for the average guy who is building a engine like this do not ask the head to do what it does not do best. Need the flow sheet. We are not running crazy CR, crazy RPM and all that entails making it live there. And you need a intake that can keep up with the head or all is for nothing. And yeah, you could have gotten 95% of your pump gas power with 60% the money spent on heads by runing Daves E heads and SS valves vs your High Ports and double Ti valves. Do not need the Ti valves unless turning high RPM so do not cam it to make power way up there. Get it done at a RPM most can afford. Its a LOT more $ to run more RPM to make a little more power. This is the street section. |
#52
The AFR 305 has a small throat, a min CSA of 2.993 sq. in. The mean CSA is just a bit larger, close to 3. This said, For a 461 engine the AFR 265 will kill an AFR 305 on the dyno up to 5000 RPM. All things the same. Peak power not much different if correctly cam'd. The AFR 290 is the beast I'd want to make BBC power up to 7000 RPM. minCSA 2.895 sq. in. An explosive head. Last edited by pastry_chef; 08-09-2020 at 03:42 PM. |
#53
I've got a similar setup, just a little lower CR...this is the cam I've got:
https://butlerperformance.com/i-3164...D3317%252F3318 BP/COMP Custom Cam- 3317-3318-HR112 (HR) (Std Firing Order/ Std Journals) 294/300, 242/248, .540/.563, 112 +4LS No issues with brakes. The biggest problem I've got is overpowering my tires off the line.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning. |
#54
Already been done with a 242/248 HR 462 using 87 cc E-heads and a Performer RPM.... Many years ago
#55
Please show me a 496-505 that has made 850+hp with wilcox heads and backed it up with track results. And DON'T say Gach!! I have saw a text from wilcox where he says he had bench issues and never had a 400cfm port his bench was wrong. Not even sure why you're posting in this thread, you have offered now useful info. |
#56
Agree with the port volume comparison.
But I think the port length of the exhaust has a lot to do with this also? (like 3.5" length for BBC to like 5.6" for Pontiac) Also takes getting all that 'stuff' out to make power. The port speed would help on discussion probably.
#57
"Maybe SD cams Road Paver with 1.8 rockers is the ticket?"
Regarding that comment, Comp lobe 3123 would be a better fit on the intake side. More aggressive than the RP and closer to what Stan posted on the intake side. 3123 .006 300 .050 246 .200 169 .4000" lobe lift .
#58
Many years ago the other wideport fellow provided these flow numbers:
Intake: .200=140.3 corrected cfm .300=222.1 .400=285.4 .500=330.7 .600=340.4 .700=359.4 .750=360.6 Exhaust: .200=114.4 corrected cfm .300=168.4 .400=207.6 .500=240.6 .600=251.1 .700=255.7 .750=258.3 ----------------- I asked Dynomation 6 what it thought. Started with the Road Paver cam and 1.65 rockers. Asked it for best average power from 4500 to 6500. Results for 1.65 rocker - .400 lobe HYDRAULIC ROLLER. Average power is pretty much a wash for all of these. 259 / 264 @ .050 110 LSA - 111 IC .006 valve duration 334 / 338 -------------------------------------------------- 261 / 268 @ .050 112 LSA - 112 IC .006 valve duration 336 / 342 ---------------------------------------------------- 261 / 264 @ .050 111 LSA - 112 IC .006 valve duration 336 / 338 ------------------------------------------------------- 259 / 268 @ .050 111 LSA - 111 IC .006 valve duration 334 / 342 ------------------------------------------------------ 261 / 266 @ .050 111 LSA - 112 IC .006 valve duration 336 / 340 ------------------------------------------------------- 261 / 264 @ .050 112 LSA - 112 IC .006 valve duration 336 / 338 |
#60
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
