Old 12-19-2006, 05:52 PM
spartazoo's Avatar
spartazoo spartazoo is offline
Default Opinions Please...
Should I paint my aluminum heads to match the look of what a SD engine looked like in the day? I have already changed to stock painted valve covers and spacers because these did not really clear the master cylinder.
Thoughts?
ID:	76344   Click image for larger version
Name:	enigine on run stand.jpg
ID:	76345   Click image for larger version
Name:	engine fitted to car.jpg
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
Old 12-19-2006, 06:26 PM
fasteddy's Avatar
fasteddy fasteddy is offline
Spartazoo, I would leave the aluminum showing- The paint chips every time you go to work on the top end. Aluminum does not paint well either. JMO
fasteddy
Old 12-19-2006, 06:58 PM
White Warrior White Warrior is offline
Leave them bare aluminum.
Old 12-19-2006, 11:43 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
If it were me, I would paint them, but I would also paint the pulleys (not engine color but black. Either go one way or the other.
Old 12-20-2006, 05:09 PM
tom s tom s is offline
get a set of real 63 SD valve covers and SD alt bracket,paint the balancer and pullys black as said.JMO,Tom
Old 12-20-2006, 10:54 PM
rod cole rod cole is offline
Default opinion
paint it all silver claim its a aluminum 303 like tom s has and that they all came that way from the factory. nice ride
Old 12-21-2006, 08:25 AM
spartazoo's Avatar
decision has been made...engine will be finished to look like a "right" SD. Valve covers have been ordered, I am tracking down a alternator bracket, will be either painting or coating the pullys, and painting the heads.
I spent a ton of time and effort to find a matching set of "correct" appearing carbs so that I could use the correct fuel lines, I might as well finish it that way.
Thanks for the input.
PS. see Tom in the end I am not that cheap...LOL
