Old 02-01-2012, 05:12 PM
LeighP's Avatar
LeighP LeighP is offline
Default Rear Bumper Area Questions.
Hi all,
Couple of quick questions on the rear bumper area for my project.
1. the small panel that sticks out under the tank filler. I understand there is some kind of seal or rubber bumper that fits onto the edge of that piece between the panel and the chrome bumper. Does anyone have more info or pics of this?
2. I do not have a licence plate light, does anyone have pics of the light itself, how it's fitted and where the wiring runs?
Any help is much appreciated.
Thanks.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 02-01-2012, 07:20 PM
BuckeyeOcean71Bird's Avatar
BuckeyeOcean71Bird BuckeyeOcean71Bird is offline
The license plate light bolts/screws to the fiberglass panel in the cut out just above the license plate when mounted. There is a ground strap that hooks to the lamp and then bolts into the rear tail panel metal. The power wire to the lamp has a grommet on it and goes through the hole in the tail panel just above the fuel filler neck hole.
Old 02-01-2012, 11:05 PM
Formulabruce's Avatar
Here is the little ground strap that you will need to find as its mounted in the plastic panel, grounds the bulb
I have a spare light assy but its not in good shape, Im sure there are better in here. I do not have a spare ground strap
Old 02-02-2012, 05:24 AM
LeighP's Avatar
Thanks....that helps. I found a repro light assembly at the Parts Place. The only PY listing said their part specifically did NOT fit 70-73 Firebird....so, it was off to the competition.
I'm guessing I'll have to fab up a ground as per the pic. Thanks.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
Old 02-02-2012, 02:39 PM
TA455HO's Avatar
TA455HO TA455HO is offline
Leigh, try this link and if there is not enough detail let us know. I can take more pictures of how that piece installs if needed.
http://forums.maxperformanceinc.com/...d.php?t=583031
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
Old 02-03-2012, 05:57 AM
LeighP's Avatar
Thanks very much....I knew I'd seen it referred to before. If you have another pic of it mounted, that would be great.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
Old 02-03-2012, 09:38 PM
GRNMTGOAT's Avatar
GRNMTGOAT GRNMTGOAT is offline
Hi Leigh, these any help ?? lots of overspray !! Neither is mine.Regards Bruce.
ID:	273214   Click image for larger version
1970 T/A RA3 #'s match.
Old 02-03-2012, 09:47 PM
LeighP's Avatar
Thanks, Bruce...that helps to see the light in situ. Appreciate it.
Regards,
Leigh
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1979 Trans Am 403
1969 Firebird 350
Sydney, Australia
Old 08-11-2018, 02:37 PM
kaptinkafeen kaptinkafeen is offline
Default rear ground strap
Sorry to resurrect an older thread, I am in need of a photo that illustrates how the rear ground strap is situated. My car has the strap (it's covered in over spray ), and it has a "jimmied" wired that is bolted to it, with the opposite end bare. Based on what I am reading here, the ground strap makes contact with the plate light assembly to ground it out. Am I correct in this interpretation.
Thank-you!
-Andrew
-probability is fundamental, uncertainty is inevitable
[B]Looking for a '71 casting rochester 7042270 - have a '72 dated 7042270 that can trade?
Old 08-11-2018, 04:10 PM
I'm attaching a photo of what I am seeing in the rear of the car in hopes members can help me out.
The ground strap that earths the plate bulb is visible. It's bent out of shape as it doesn't come close to making contact to the chassis of the bulb socket. I'm assuming it was bent when the car was haphazardly repainted a long time ago.
How does the ground strap attach to the socket. Should there be holes at either end of the strap (one to mount the strap to the car body, and another to permit it to hang off of the mounting screw?
Additionally, should the strap be painted body colour, or is it raw steel?
Again thanks-you for the info!
-A
As an aside, my license plate bulb lense is half painted grey. Looking at reproductions, the lense is clear, while looking at a fellow member's ride (photo attached from another py thread, the lense is also painted) - what is correct?
ID:	490185   Click image for larger version
Name:	Screen Shot 2018-08-11 at 2.54.32 PM.jpg
ID:	490186   Click image for larger version
Old 08-12-2018, 04:07 PM
FunctionalShaker FunctionalShaker is offline
The reproduction lenses are different from the originals (pic is correct). The ground strap is held to the housing by one of the mounting screws and the other end to the inner tail panel (like in your pic). Your strap is bent out of shape. I believe they were just bare metal originally as the lamp assy. would have been installed after painting.
Old 08-12-2018, 05:08 PM
Here's the drawing from the assy. man.
Old 08-12-2018, 09:50 PM
Perfect! Thanks for the image.
-A
