Missing Pontiacs, Parts or Trailers Include lost or stolen items here
Old 12-25-2023, 10:50 AM
Brendan 65 Brendan 65 is offline
Default 1970 455 HO motor WA trying to reunite if still in existence
I have this 1970 455 WA motor in my car, trying to see if the car is still in existence and if so wouldn't be against selling it ro reunite with the car.
0386369
WA
Old 12-25-2023, 03:01 PM
turbo69bird's Avatar
Good job my friend always nice to reunite a block w the car.
How it finds its original car.
960 HP @ 11 psi, 9.70 at 146.
The Following User Says Thank You to turbo69bird For This Useful Post:
Old 12-25-2023, 03:30 PM
Default Partial VIN ?
Does the block have a partial VIN down next to the timing cover?
That will be what signifies which vehicle it was installed in originally.
The number above the 'WA' is the Engine Unit Number (EUN) and is kind of a serial number that Pontiac used to keep track of engines.
Unfortunately, there are no records of which vehicle the engine went into based on that EUN for the 1970 model year.
Good luck with the search!
Name:	partial vin and EUN.jpg
The Following User Says Thank You to Joe's Garage For This Useful Post:
Old 12-25-2023, 04:26 PM
I will check for check for the vin sequence next time I am with the car.
Old 01-01-2024, 07:17 PM
As it turns out it looks to be an over the counter motor, no vin on the front of the block and no evidence of any removal.
Thank you for the information.
Just figured I would make sure someone wasn't searching for it before I did anything to it.
Old 01-01-2024, 08:17 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
https://forums.maxperformanceinc.com...d.php?t=793308
It could be a Fremont built cars engine. Look to the left of the EUN. Block should be cast around A160. If so, car would be mid-February build.
So long, farewell.
Old 01-02-2024, 07:19 PM
What's the cast date code by the distributor?
Old 01-17-2024, 12:19 AM
This is a picture of a 71 455HO block out of an A body car built in the Fremont plant. You can see the partial VIN on the far left of the picture, just below the block deck. Block date code was I020 and the casting number was 483677.
