4 speed setup
Want to convert an auto to manual and would like to buy the parts to complete the task:
z-bar z-bar frame bracket reverse/steering column linkage crossmember clutch fork pedal assembly rear trans mount (rubber) Let me know what you have. Thanks
Home of WFO Hyperformance Shaker induction. |
What year? I have the pedal assembly for '73?-'81
I have everything but the trans that came out of my 74 ventura, not sure if it is the same as what you need?
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
PM sent. Have most if not all of that stuff from a 71 Bird.
1999 Trans Am Ws6 Slp Lid, K&N, Smooth Bellows, Ls6 intake, Spec Clutch, Spec Alum. Flywheel, Spintech Cat back. 1970 Firebird Esprit 455 Pro Street project |
4 SP CONVERT
4 speed conversion - everything needed
I have every piece needed to covert to stick. All came off of 79 formula, said to fit 70 - 81. T10 tranny, bellhousing, flywheel,crossover, pedals & every linkage piece. I am in Michigan, make me a good offer
pedals etc: http://forums.maxperformanceinc.com/...d.php?t=599211
console: http://forums.maxperformanceinc.com/...d.php?t=599098
Gregg V. |
i have pedals z bar rod not too proud make offer
