Old 06-01-2012, 02:31 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Pretty please... a picture of the Moldex crank?
Old 06-01-2012, 08:24 AM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Caution on how big of a stroker you put in the 4 cyl block. No room on the left side of the motor for rod clearance. You will have to modify the side of the block like Mickey did!
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 06-01-2012, 08:40 AM
63Banshee's Avatar
63Banshee 63Banshee is offline
Something like that...
Old 06-01-2012, 08:46 AM
Or are you going to use the right half of a V8 block?
Keith Collier
Tech advisor
POCI.org
Old 06-01-2012, 09:01 AM
63Banshee's Avatar
No. I have a small collection of thick wall blocks and about to add 1 or 2 filled '63 blocks to the inventory. The 6765 ball bearing turbo and plumbing will take up the driverside of the engine bay.
Old 06-01-2012, 09:23 AM
Bill Hanlon's Avatar
Looks like the pan needed a few expertly applied licks from a BFH as well.
Old 06-01-2012, 09:44 AM
Steve Barcak's Avatar
Quote by Bill Hanlon
"Plus you'd need to have something (two rod caps bolted together??) to take up the space on the crankshaft where rods for V8 cylinders 1,3,5 & 7 are now missing. And that "something" would likely not match the balancing of the V8 crankshaft very well."
Bill,
I checked with my crank grinder on this aboput an idea I had. The idea was to simply have him machine/grind 1/2 the width of the rod journal ( 8 cyl crank ) undersize instead of the entire jounal.
This would appear as a step over the width of the journal. This would keep the rod where you want it and not have to add weight on the other portion of the journal.
He said that should work.
Others in the past have used 2 rod caps bolted together on the unused portion of the jounal as you suggested. I do not care for that idea.
I also have interest in building a 4 by using a v8 block and crank and looking into many ideas on this with displacements as small as 141 cu in..
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 06-01-2012, 10:04 AM
Bill,,,Mickey did the oil pan kick out on many of his engines. Added oil capacity.
Keith Collier
Tech advisor
POCI.org
Old 06-01-2012, 02:36 PM
I'm not talking about the 1/2 round "kick out", I'm looking at the lumps here:
Old 06-01-2012, 08:17 PM
My bad!!! Didnt even see that!
Keith Collier
Tech advisor
POCI.org
Old 06-01-2012, 10:06 PM
Steve:
If you started with an unmachined crank (or used rods with a smaller big end than Pontiac rods) your idea about having half the rod journal of a V8 crank not turned all the way down would seem reasonable to me (the guy that only does theoretical performance engine builds), but you still would be stuck with uneven power strokes.
Cylinder 1 fires (this is cyl 2 on the V8)
crankshaft turns 180 degrees
Cylinder 4 fires (this is cyl 8 on the V8)
crankshaft turns 90 degrees
Cylinder 2 fires (this is cyl 4 on the V8)
Cylinder 3 fires (this is cyl 6 on the V8)
crankshaft turns 270 degrees
back to Cylinder 1 at the top
Maybe that isn't important in your application, but the title of this thread is "a smoother 4 banger? 389 crank 389 cam?" and I doubt this uneven firing would help with smoother running.
- Bill
Old 06-01-2012, 11:44 PM
Steve:
- Bill
Bill,
I understand what you are saying and it is valid, or potentially valid. I say potentially only because I have yet to try it.
It is only in the idea stage. I am sure shortening the stroke on the Tempest would smooth it out considerably.
However, with so many smooth running 4s out there, there must be a way to make the little Tempest prrr.
Hosting-
Phil 2:11
Old 06-01-2012, 11:47 PM
63Banshee's Avatar
Bill, you're formally invited to come by when I get the first one running. Probably 2 months after Norwalk. That's priority right now.
Old 06-02-2012, 03:15 AM
re: uneven cylinder-firing intervals.
This typically isn't detrimental. In fact, depending on application, it has been done purposely. Examples include the old John Deere tractor two-cylinder engines, which had firing intervals of 180` and 540`. Supposedly this took best advantage of the behavior of lug-type tire treads in soil. A recent example is what Yamaha calls "cross plane cranks" in their GP racing bike engines; again for some supposed on-track improvement in power delivery to the pavement.
Inherent imbalance of a particular engine configuration (e.g. inline four cylinder) is due to inertia force vectors (of crank/rods/pistons), not combustion forces. In other words, such an engine would vibrate even if not "running", but being spun by external means (electric motor or whatever). [At least that's my hypothesis; feel free to prove me wrong]
Old 06-02-2012, 03:19 AM
Why are you owners of billet 4-banger cranks so reluctant to display a picture (Bansee and Rusty4cy). Please tell me what the "price of admission" is...
Old 06-02-2012, 09:00 AM
Rusty4cyl's Avatar
Rusty4cyl Rusty4cyl is offline
Jack, I haven't seen it yet either. Calvin is picking it up , maybe next week. So I can't help you yet, If I had it here I would take pics for you. Sorry, I can't help you yet. I'm waiting to see it too Thanks Rusty
Blown 4cyl's to the front
Old 06-02-2012, 10:00 AM
63Banshee's Avatar
In a similar boat as Rusty, but mine is a V8 crank.
  #38
Old 06-03-2012, 02:11 AM
Thanks, guys- I look forward to seeing crank pictures.
Banshee- any particular reason you won't be using a flat crank?
  #39
Old 06-03-2012, 09:21 AM
63Banshee's Avatar
Several reasons. Cheap stroke options being #1.
  #40
Old 06-04-2012, 09:35 AM
I am honored by the invitation. Keep me updated. I'll be in the Dallas area July 14ish and SWMBO is talking about another trip to Dallas to visit with her cousins later in the year.
