Old 12-11-2016, 03:19 AM
elefantrider's Avatar
elefantrider elefantrider is offline
Default '62 4cyl/auto Crank Seal
Anyone ever try replacing the factory rope with a 2pc BOP viton seal with the 4cyl engine still in car on tempest?
- can you get the oil pan off in car?
- if not, to make room, can you jack up the engine a few inches with the torquetube still attached? Or will that risk cracking it?
- if engine needs to come out, what are best 4cyl anchor balance points for the chain sling? Back of head/ front of head 3/8 bolts?
Old 12-11-2016, 07:14 PM
tom s tom s is offline
here is how we hung it
Old 12-11-2016, 07:15 PM
Chris,too big file,will email.Tom
Old 12-12-2016, 03:32 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Best to pull the motor. Use the new BOP 1 piece seal.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 12-12-2016, 03:35 PM
2X on the one OC.Tom
Old 12-12-2016, 03:49 PM
Thanks. Do you need to fully remove the crank for the 1pc BOP seal, or can you get it in just lifting the crank a little?
I have the 2pc seal (new in package) and it does not flex at all.
Old 12-12-2016, 05:33 PM
Chris,im 50/50 with the 2pc BOP seal.Im 100% with the 1 pc BOP and the Best gasket rope seal.The 1 pc seal is pretty much a 2 man job and the crank needs to be more than just lifted IMO.Tom
Old 12-12-2016, 06:35 PM
Thanks guys, will try my chances with the 2pc seal because already have it.
Old 12-12-2016, 07:37 PM
might as well,the engines are like a yoyo,they go down as easy as they go up!Never have time to do it right but always have time to do it over!You MIGHT get lucky!Tom
