Old 03-24-2007, 02:51 AM
MalteseFalcon's Avatar
MalteseFalcon MalteseFalcon is offline
Default 88-89 16x8 GTA rear wheel offset
Am I correct that the rear GTA wheels have a 16mm negative offset that can be brought to a zero offset with the use of a 16mm spacer?
Or is the other way around (positive offset so a spacer won't work)? I want to use a set on a 2nd gen Trans Am.
Steve
1978 WS6 W72 4 Speed Trans Am - Martinique Blue on Light Blue - Fire Am Restification Project
1972 4-Speed 455 HO Trans Am - Original Cameo White on Blue car - Restoration Project
Old 03-27-2007, 06:10 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I can try and measure one this weekend.Yes "rears" would take a spacer to get to "zero", as they have more backspace than the fronts.
I did fit "rears" on the rear of my 78 with 255-50-16s on it no problems.
Old 03-28-2007, 10:40 PM
Thanks, Skip. I ended up passing on the wheels I found, and I found some stuff that says its 16 to 20mm, so I'll just keep looking.
Steve
Old 03-31-2007, 12:40 AM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
i used a small shim with 275/50's on my gta wheels; looked great, fit perfectly.
spacer was 3/8" if i recall.
is this thing on?
Old 04-08-2007, 05:22 PM
Skip Fix's Avatar
Back space 5 5/16".
Be neat if Stockton could take one and widen it to a almost zero offset 10"!
Old 04-15-2007, 06:36 PM
WarbirdTA's Avatar
WarbirdTA WarbirdTA is offline
On one of my cars, I run the backs on the front, and the fronts on the rear.
Since my car is dropped almost 2 and a half inches in the front, the rears (which sit on the front of the car) are tucked up under the fender lip real nice.
Maybe if my car was slammed in the front, I would try all fronts.
George
