Old 07-06-2007, 10:37 AM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
Default 89 TA rear end noise........help!!
I have a very hot 89 TA street car cruiser (10.90s) and installed the 2" lowering springs, Mosar 12 bolt 4:11, all adjustable bars underneath including the Spohn torque arm. The rear end whines like crazy all thru the car. I've tried 3 different gearsets with no help. I've moved the pinion angle up and down-no help. I finally put the stock 9 bolt back in with the stock torque arm. Guess what.....it's not as bad but the noise is still there!! I've spent months looking underneath and I just can't figure it out. Before I lowered it, the stock 9 bolt was super quiet. What am I missing here?? I have worried with this for a LONG time. I love the car but I hate to drive it.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Also I connected the front and rear subframes and added a roll cage.
Old 07-07-2007, 08:10 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
Bad tranny mount? Bad driveshaft? put the stock rear springs back in and see if that helps at all.
Old 07-07-2007, 11:05 AM
New tranny mount, driveshaft balance checked and both new u joints. I was trying to keep from swapping the springs but I may end up doing it.
Old 07-08-2007, 11:46 PM
Formulabruce's Avatar
I bet its loaded with POLY Bushings. Transfers and amplifies noise alot.
Old 07-09-2007, 01:41 PM
Mr_GTO's Avatar
It might be the adjustments on the lower control arms...did you put the relocation brackets on the rear end when you lowered the car?
