update
ok i went ahead and bought the 1964 gto gas tank and sender. the fitment is not so great. but it is installed in the car and working at the moment.
the filler neck is both the wrong angle and a bit too long i am going to see if i can get my old 2 piece filler neck welded to this tank. once this is done the fitment should be pretty good.
also the gas sender sits about 2 and half inches away from the torque converter with the fuel outlet just sticks out about an inch and then terminates so this makes running a fuel line tricky, but doable.
