Old 11-24-2011, 04:14 PM
1963vert's Avatar
1963vert 1963vert is offline
Default the right stuff.
has anyone here used that silicone for sealing the timing cover?
i pulled my motor yesterday before i went home from work, in order to take this long weekend to do the job of resealing it (326).
thanks in advance.
63 vert
Old 11-24-2011, 05:15 PM
mechanickeith's Avatar
It will work just fine. I like to use ultra grey myself. I have all parts clean & dry, run a small bead on the cover & bolt it up while wet & let it sit overnight before putting back in use.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 11-24-2011, 07:15 PM
Hooter's Avatar
Hooter Hooter is offline
My whole motor on both cars is sealed up with it. Works great. Never a leak. It's a bitch cleaning up though when you have to take it apart.
67 Bonneville ragtop
Old 11-27-2011, 12:03 AM
1963vert's Avatar
keith , hooter, thanks for your input.
today i was lucky enough to get the rear main out with out pulling the crank loose. sunday i will be installing the pan and then popping the motor back into the car.
