Old 02-23-2020, 12:51 AM
peppergreen's Avatar
peppergreen peppergreen is offline
Default 1967 Courtesy Light with A/C
Folks, searched around and finally found a 1967 under-dash courtesy light bracket, then purchased a new plastic dome lens. Not sure it is the right one for A/C, any have any pictures? Doesnt have enough room from the under-lip of the dash and the AC ducting. Saw a thread where it may be a tear drop shape, that attaches to the plastic ducting?
Thanks in advance
"Drive a GTO".......Iggy Pop-Lust for Life
Old 02-23-2020, 03:42 AM
lust4speed's Avatar
I don't remember any difference from my '67 with air to the other without. The A/C ducting sits up a little from the bottom flange so don't think there is any interference. I sold the A/C car so can't confirm, but swear it attached to the steel lip.
Mick Batson
Old 02-23-2020, 08:43 AM
Jeff Hamlin's Avatar
There should be enough room, It's tight but will fit. I angled mine slightly downward on my '66 with AC just to improve the light output. Your '67 should set up the same.
The only reference of a variation is on the convertibles which IIRC had two under dash courtesy lights. I think it was one above each footwell.
Old 02-23-2020, 03:31 PM
lust4speed's Avatar
My friends car that came with the 8-Track tape player had a light on each side of the player. When I added the Mark IV Vintage Air I took the idea and moved the original over and purchased a second for the other side.
Mick Batson
Old 02-25-2020, 02:10 PM
GT182's Avatar
GT182 GT182 is offline
66 was the same, but when I added the courtesy lights to my 66 I put one on each side. Sure makes the lighting better for the foot wells.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 02-26-2020, 07:14 AM
Jason67's Avatar
Jason67 Jason67 is online now
Thanks in advance
The teardrop shaped one was used with A/C and 8 track on passenger side Check out Page 452 on the assembly manual, when you got A/C and an 8 track, two holes would be drilled in the plastic duct to accept the teardrop light. On the back side of the teardrop light style, there is a alignment tab that fits in the smaller dia hole, then the screw for the larger dia.
Jason
Old 02-28-2020, 12:20 AM
Thanks for the great info everybody. It is in.....and it's tight. Not much room, finger feel to get it started, and pull it down with the screw. It won't rattle, put an LED in there. Before/After pic and pg 452 of the assembly manual that Jason referenced for 8 track cars.
ID:	533187   Click image for larger version
ID:	533188   Click image for larger version
Old 02-28-2020, 03:46 AM
lust4speed's Avatar
What LED bulb did you use? I ended up with a bulb a little too large and while it has stayed in place it would be nice to have one the fit properly.
Mick Batson
Old 02-28-2020, 07:21 AM
Unhappy
Just be aware that those crappy Repro lens' will burn/brown in short order if you use the light for long periods with a standard/stock blub.
Make your choice isn't hotter.
Old 04-07-2020, 06:24 PM
RedDirtRoad RedDirtRoad is offline
Looking to buy the bracket as well
I know I have at least one one of these but just can’t find them
If anyone has one or a source let me know
