Old 12-31-2019, 09:06 PM
gto19's Avatar
gto19 gto19 is offline
Default 1967 gto ashtray trim
So today I was checking my ashtray and cigarette lighter lights and I noticed I was missing the ashtray trim . My car is a early 67.....11-c-66 built . Maybe my car didn’t come with that piece being a early car ? It looks like the screws have never been off where the trim would mount . Oh btw the original bulbs still work .
The picture of the trim piece is not from my car . I found it on the Internet
What do you guys think
ID:	527924   Click image for larger version
ID:	527925   Click image for larger version
ID:	527926   Click image for larger version
ID:	527928   Click image for larger version
Old 12-31-2019, 10:55 PM
400 4spd.'s Avatar
I believe that trim piece was held on by Phillips screws, not the 1/4 hex heads you have. I can verify that tomorrow. I'll bet your trim piece was removed.
Old 12-31-2019, 11:50 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default 67 ash tray trim
Don’t quote me but I recall the first half of the 67 builds did not have the ash tray trim piece.
Later in the 67 year that trim was added because the 1966 and early 67 the plastic would burn/melt from cigarettes.
Here is an 11D PON built car without it.
Chris
ID:	527941   Click image for larger version
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 01-01-2020, 11:39 AM
gto19's Avatar
Thanks guys
I have a feeling my car did not come with the ashtray trim
Old 01-18-2020, 12:49 AM
Mcronk Mcronk is offline
Mine does not and it also was a November 66 build.
Old 01-18-2020, 10:39 AM
blue67gtoragtop's Avatar
blue67gtoragtop blue67gtoragtop is offline
Mine is an early December 66 build and it has the ashtray trim
Old 01-18-2020, 11:17 AM
richardk's Avatar
richardk richardk is offline
Mine was built last week of Nov. '66, in Pontiac, and has the trim piece.
"I fishtail through the lanes, and I make my tires squeal.
Power at my feet, and glory at the wheel.
I wind the windows down, let the wind blow through my hair.
God knows where I'm goin' to, but me... I don't care."
Old 01-18-2020, 11:34 AM
gto19's Avatar
I’ve come to the conclusion my car did not come with this piece
Old 01-18-2020, 06:06 PM
rockdoc's Avatar
rockdoc rockdoc is offline
I had the same issue. I noticed that my early 67 did not have this trim piece. I eventually found one and tried and tried to get it to fit. I could get it on, but the ash tray would not fit properly with it.
In the end I too decided that perhaps I never had one, and for sure it doesn't fit properly. So I left it off.
Old 01-18-2020, 08:01 PM
60sstuff's Avatar
The “second design”, later 67 dash bezel was notched at the ash tray opening to accommodate this metal trim.
If you have the “first design” bezel without the notch, this small trim won’t work and the ashtray alignment will be off.
You can clearly see the notch on both photos below.
First pic shows the trim.
Second pic just shows the notch without the trim piece.
Chris.
ID:	529092   Click image for larger version
