Best header gaskets
What header gaskets are you all using? I’ll be running Doug’s round port headers on Edelbrock aluminum heads. I’ve heard a lot of people have success with Remflex but have never personally run them myself. I also have heard of people using The Right Stuff gasket maker with good success but I’m not sure about that since it’s only rated to 450 degrees.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
Remflex for sure.Tom
I have had different sets on mine my top picks ....Remflex /Percys....
For Sure Remflex for the street, we also had great success with Permatex Ultra Copper as well for our race engines, but for the street you cant best Remflex..
1978 Trans Am Pump Gas 461 Stroker |
Same application. I use regular old Mr. Gasket, they work fine.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Remflex here as well. Before they get squeezed though they are thick, so you might need longer header bolts.
Alright, remflex it is, I see on their website, they claim there is no need to retorque after a couple heat cycles, is it best to retorque anyways?
You need to at least check them. I had a couple come loose after the first time.
Remflex here too..... never a leak
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
1965 Pontiac LeMans. M21, 3.73 in a 12 bolt, Kauffman 461. |
6... Not on my Pontiac but on my Datsun Z with header. I will highly recommend.
Greg Reid Palmetto, Georgia |
must be the odd one but I run standard Fel pro header gasket....never have leaks. Seem to last 5 years or more. They stay tight as well.
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
High temp RTV on a street 455 D port with Hooker headers since 1990............
Felpro blue header gaskets are excellent. Never had a leak using one to date no matter how poorly made the headers were at the flanges.......Cliff
I used Mr Gasket on my round port 428 with Doug's headers. However, I had to double up on the gasket to make them seal off good.
Fel-Pro. Blue gaskets here.
I ran the Doug's gaskets that came with the headers for years. When I moved the headers to my 455, I ordered new "Doug's" gaskets, I believe from Summit. A completely different gasket. Neither leaked...or, I guess in the case of the newest ones, leaks. Flat mounting surfaces, thick flanges and the right bolts will generally get you no leaks with a decent gasket and a little bit of care.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
I use copper. With a good header and mounting flange they've worked good for me for a couple decades on a few cars, and are reusable.
I use the Mr. Gasket Ultra-Seal ones, the grey ones, they work really well, and easily available.
Been using my copper gasket for 20+ years with no issues. Couldn't tell you what brand though.
- Mike '69 Firebird 400 - Goldenrod Yellow, 455 +.060, '6s-7' heads, Comp Cam 276AH-10 (51-309-4), TH400, Ford 9-inch w/3.08, 800cfm Q-jet, Stock Intake, Hooker Headers, Flowmasters '68 Coronet 500 Convertible - Medium Gold Metallic, stock 318 +100,000 miles |
Thread Tools | |
Display Modes | |
