Old 03-07-2018, 05:39 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default California Pipe
WTB,
1964/1965 Black painted Pipe which goes from the LH valve cover over to the center carb base.
Used with the K24/614 option. Part #9776773
Please PM me.
Thanks, Chris.
Old 08-29-2018, 07:07 PM
60sstuff's Avatar
Default Bump
Still need this OEM metal pipe.
Thx, Chris
Old 08-29-2018, 08:26 PM
BOB VIDAN BOB VIDAN is offline
Whew, wasn't sure what you were looking for. What I was thinking you'd never have to write an ad for, probably pick one up at any middle school down your way. Oh God what did I say?
Practicing social distancing for 65+ years
Old 12-11-2018, 10:01 PM
60sstuff's Avatar
Still in need of this 64/65 metal pipe as shown above and in the MPC #6.
THANKS, Chris
ID:	499967   Click image for larger version
Old 02-15-2019, 11:26 PM
aceaceca's Avatar
aceaceca aceaceca is offline
I have 2 end carb bases for this set up.
Old 02-16-2019, 12:41 AM
wbnapier wbnapier is offline
Ames sells this reproduction. Both tube and bases.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 02-16-2019, 02:36 AM
60sstuff's Avatar
wbnapier,
Thanks for the reply, but my ad is asking for an “OEM Pipe”, not a reproduction.
I have plenty of all 3 California bases, but not the Original pipe that goes to the valve cover.
Thanks again, Chris.
Old 11-17-2019, 04:09 PM
60sstuff's Avatar
Default BUMP
Still need this “Pipe” for a 64-65 Tri-Power.
Must be “Original”, not repro.
Thank you.
Old 11-17-2019, 04:58 PM
GTO3DEUCES GTO3DEUCES is offline
In my opinion, one of your best bets is to contact Mike Wasson at:
https://pontiactripower.com/
I wouldn’t be surprised if he in fact had it...
Best Regards,
Dave - GTO3DEUCES
Old 11-17-2019, 05:40 PM
My other suggestion is to look at other Pontiac models from that year and any associated forums, as likely many were the same for California emissions.
One more thing, I’d place an ad into both the GTOAA ‘Legends’ monthly magazine as well as the monthly POCI publication ’Smoke Signals’. You’ll garner alot of exposure in their classifieds.
Best Regards,
Dave - GTO3DEUCES
Old 04-27-2020, 05:04 PM
60sstuff's Avatar
Default Bump up ^
Still needing the Factory Original black painted pipe that goes from center carb base to the LH valve cover..
Will purchase the full set-up if that’s what it takes.
Thank You, Chris.
