Old 01-06-2020, 06:35 PM
sdbob sdbob is offline
Default Trouble with 2nd Generation Ignition Switch Choices.
Bought new switch from NAPA for 72. Switch sticks in start position. Tried another at NAPA same thing. Tried to cycle it 20 times ,to work any 'rough' spots smooth. No luck. Any other choices out there that has worked for you? Now thinking maybe look for NOS.
Old 01-06-2020, 06:58 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
I have never had any luck with ANY electrical or electrical related part from NAPA. Maybe try a different parts supplier. My new ignition switch came from American Autowire for my 67 GTO. Smooth as silk and trouble free for the last 4 years.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 01-06-2020, 08:06 PM
Sirrotica's Avatar
AC Delco still lists one for tilt and one for the standard column. I used to have good luck with AC Delco electrical parts, but as with everything who knows how the quality is at this point? ...............
Part #s
D1404B no tilt
D1405B with tilt
Wish you luck............
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 01-06-2020, 08:47 PM
77 Canamman's Avatar
NON tilt:
Tilt:
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 01-06-2020, 10:40 PM
Grand73Am Grand73Am is offline
I wonder if he actually means the ignition lock cylinder and not the actual "switch" that's on the column under the dash.
Steve F.
The Following User Says Thank You to Grand73Am For This Useful Post:
Old 01-07-2020, 06:52 AM
The switch where the harness plugs in. It is tilt.Sorry.
Old 01-07-2020, 06:55 AM
Thanks guys.
Old 01-07-2020, 07:14 AM
Is the return spring too weak or linkage binding up when you bolt the switch down?
Clay
Old 01-07-2020, 07:31 AM
Make sure it's for a tilt column?
They are opposite of the non-tilt switch.
(Start on opposite end of the non-tilt)
Maybe you are 'sticking' in the 'Accessory' position?
See if it works moving it on the opposite end?
Compare the switch to the one you took out.
The connector posts will be opposite if wrong.
Old 01-07-2020, 09:56 AM
I had tilt column on bench. Beside regular column on bench. Yes I played with linkage rod. Lubed it.The old working switch worked fine.There seemed to be a 'catch' in new switch,not allowing it to come from start to run. I thought ,in use it would loosen nope. Went to NAPA looked at 2nd new switch.worked it there same problem. I had 2 more oem original tilt column switches they come off start to run,easily but will not function electrically. When I test I try to look at everything, keeping it simple.
Old 01-07-2020, 11:11 AM
455rebel 455rebel is offline
On a similar note, last 3 (3 different cars) key switches i bought were notchey . Filed on the keys to free them up.
And one of my trucks floor dimmer switch ,GM, has benn replaced 3 times in 5 years!
Quality of parts is getting ridiculous!
1970 amc rebel 4-door, faded blue paint,290 emblems on car, 455 under the hood.Turbo 400,3.15 gear.
Best so far 1/8 et,8.90 on street tires,
Since that I have added 400 heads.
I call it a rat sleeper.
Old 01-07-2020, 01:46 PM
Formulajones's Avatar
I just recently had to replace the original switch in our 69 Camaro. Went to Napa and bought one of their Echlin brands. While it does work okay, it is excessively stiff to move, especially for the crank position. I've noticed after daily driving the car for the last 2 months it's gotten slightly better, or maybe I've just gotten used to it. Wife drives it and she hasn't said a word about it so I'm good, lol.
I figured I'd let it ride for a while since it works fine, because at some point I'll be switching over to a tilt column anyway so I don't want to go chasing non tilt ignition switches. At that point I may try a different brand. Most likely from American Auto Wire since I've liked their products on other restorations, and I need a couple other things from them anyway.
Old 01-07-2020, 02:58 PM
STEELCITYFIREBIRD's Avatar
If the switch doesn't stick operated alone out of car, the problem is in the install or the column itself.
Also check if column position/tilt makes any difference.
Old 01-07-2020, 08:21 PM
It's the switch. Used rod to move switch outside of column. I learned take everything out of car. It wasnt a simple replace.
