Old 04-05-2003, 11:17 PM
robert strohrigl's Avatar
robert strohrigl robert strohrigl is offline
ENGINE IDENTIFYING HELLLP???
please help identifying this motor?
i got it cheap for parts, and it runs good
anway here the numbers
on the front of the block YE 0850273
REAR BLOCK NUMBERS
97999916
INTAKE 9790413
EXH MANIFOLD 9779328
HEADS ARE HARD TO MAKE OUT? 1 THEN (4)? (5)?(7)?
OK ME THINKS ITS A 1970 (350) WITH 265 HP 9.2 COMPRESSION
CORRECT ME IF I'M WRONG?
IT ALSO HAD NON GTO MOUTOR MOUNTS, THE HAD HOLES (TO MOUNT) RIGHT IN THE MIDDLE OF THE MOUNT
GTO'S HAVE THE BOLT THAT RUNS DOWN THE CENTER LONG WAYS
ANYWAY I JUST WANTED TO SEE IF THIS IS SUITABLE, TO THROW IN MY 68 GTO, TIL I FIND A GOOD MOTOR, OR GET MY 68 YS BLOCK BUILT
I PLAN ON PULLING THE 2BBL INTAKE AND CARB, AND EXH MANNIES, AND REPLACING WITH A 4BBL EDELBROCK PERMORMER AND A 3124 HOLLEY AND HEADERS
ANYONE HAVE A SET OF DECENT USED HEADERS?
ALSO ANY INFO AND INPUT IS EXTREMELY APPRECIATTED HERE?
THX BOB
ALL AMERICAN PONTIAC LOVER
I have many 442 Cutlass and Gto parts if you need anything let me know?
God Bless Bob
MY TOYS
68 H/O Demmer #196 OF 515
68 GTO 20K H D-GATE 3:31 POSI NEW BUILT YS 400 & DRIVETRAIN OLDER NICE BLK PT NICE INT HTACH SPOILER NEW & VERY NICE CHROME, FREMONT CA BUILT
69 GTO 8K #S MATCHING DRIVELINE RARE OPTIONS BENCH SEAT CRUISE DISCS POSI AC H-AWAYS FIXED SETUP COMES W A H-AWAY SETUP STILL RUNS STRONG
66 NOVA POST 327 D-HUMP HEADS AUTO 411's
68 CS 7K POST BUILT 403 C HEADS
REAR BLOCK NUMBERS
97999916
INTAKE 9790413
THX BOB
God Bless Bob
MY TOYS
Old 04-06-2003, 12:22 AM
Jack Blum's Avatar
Jack Blum Jack Blum is offline
Rear block number 9799916 matches a 1970 350. The 9799 denotes 1970 part number. But the YE does not match up for 1970. The only 350 block codes I see for 1970 are WU,YU,WR and XR. I do show a YE for a 1969 350 with head cast of 47. Head casting letters for 1970 350's are 11 or 94 only.
If it is later than 68, the cid will be on the side of the block on the left (drivers) side to the left of the motor mount.
I am looking in Pete McCarthy's book.
TigerEFI.com (Classic Pontiac Fuel Injection) Jax.GTO@gte.net
Motto: Build it for NASA and drive it like you stole it!
2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration.
Old 04-06-2003, 01:10 AM
THATS WHAT I'M SEEING TO
ITS FOR SURE 9799916
AND ITS AGAIN FOR SURE A YE CODE
IT ALSO HAS A LARGE "70" ON THE REAR (NEAR THE DIST TO THE LEFT)
AND IT HAS 350 EMBOSSED INTO THE BLOCK ON THE DRIVERS SIDE
IN ADDITION, IT HAS (FOR SURE A 1) ON THE HEAD, AND THE OTHER NUMBER IS HARD TO READ , BUT SEEMS TO BE SOMEYHING OTHER THAN A 1
VERY VERY HARD TO MAKE OUT?
14'S?
I CAN'T FIND THE YE 350 IN 70 WITH THE 9799916 CASTING BLOCK NUMBER?
WEIRD?
ITS FOR SURE THIS CONMBO?
THE ENGINE LOOKS GOOD, EXTERNALLY, NO LEAKS, PRETTY GOOD PAINT , NO OIL ETC
I'M GOING TO CHANGE TO 4BBL AND HEADERS AND HOPE FOR THE BEST,
THINK IT WILL BE OK?
THE GENTLEMAN I GOT IT FROM (FOR $100) SAID IT WAS IN A 68 VENTURA, AND THAT HE WAS TOLD IT WAS FROM A 658 FIREBIRD LOL, THE PLOT THICKENS
THX BOB
God Bless Bob
MY TOYS
Old 04-06-2003, 10:34 AM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Your intake is for a '68. Maybe the heads are also from the same '68 (17 heads for 350, 14 heads for 400). The YE was a '69 Firebird 350 code, which was produced into the early '70 model year, hmmm.
So long, farewell.
Old 04-06-2003, 09:05 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
Pull the intake and the valley cover. In the center ribs of the lifter valley on 68 and later blocks will be a '50' for a 350, '28' for 428, '55' for 455.
Motors will also have the CID as part of the block casting below the most forward freeze plug, or behind the dipstick tube on the other side.
TIGER EFI - Electronic Fuel Injection for the Traditional Pontiac Engine. bill@tigerefi.com
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
