Old 07-07-2016, 01:45 PM
SD455DJ SD455DJ is offline
Default 33K Survivor Formula 455 RamAir Pics
Here are a few pictures from an all original unmolested 455 RA Formula from the Norwood plant. I took these pictures for future reference. I wish I remembered to take a picture of teh gas tank with the mfg stamp in black ink.
The car even had most of the original exhaust system except for the muffler and a portion of the head-pipe on the pass side (no pictures of exhaust).
Name:	AC Air Deflector L.jpg
ID:	432222   Click image for larger version
Name:	AC Air Deflector M.jpg
ID:	432223   Click image for larger version
Name:	AC Air Deflector R.jpg
ID:	432224   Click image for larger version
Name:	Factory Belts & Hoses.jpg
ID:	432225   Click image for larger version
Name:	Fuel Line Clip.jpg
Old 07-07-2016, 01:48 PM
...some more...
Name:	Front Valance Center Clip.jpg
ID:	432227   Click image for larger version
Name:	H-X Front Shock Tag.jpg
ID:	432229   Click image for larger version
Name:	Orig GY 3.08 Posi Code.jpg
ID:	432230   Click image for larger version
Name:	O-W-B Drive Shaft Paint.jpg
ID:	432231   Click image for larger version
Name:	Starter Heat Shield.jpg
Old 07-07-2016, 01:49 PM
...and more...
Name:	motor crossmember.jpg
ID:	432233   Click image for larger version
Name:	Trans Crossover.jpg
ID:	432234   Click image for larger version
Name:	TC Cover Screw.jpg
ID:	432235   Click image for larger version
Name:	Strarter Nose Bracket.jpg
ID:	432236   Click image for larger version
Old 07-07-2016, 01:53 PM
...and a few more...notice the red (closer to brown) original oxide primer on the floors. i'm sure the color changes from year to year and batch to batch. It was really a treat to see a well preserved un-butchered original car.
Dennis
Name:	Red Oxide Floor.jpg
ID:	432238   Click image for larger version
Name:	Red Oxide Floor Pass.jpg
ID:	432239   Click image for larger version
Name:	Red Oxide Floor Driver.jpg
Old 07-08-2016, 07:36 AM
US Steel stencil on the bottom of the gas tank still. Red (brown in this case) oxide primer, and mostly original exhaust system (except for the muffler and a short section at the end of the head pipe on the pass side. Alittle bit of scrubbing and some Evaporust to clean up the surface rust and it would be nice. Maybe Bentwheel Bob and MPD have extra time on their hands to take on another project (haha).
Dennis
ID:	432273   Click image for larger version
ID:	432274   Click image for larger version
ID:	432275   Click image for larger version
ID:	432276   Click image for larger version
Old 07-08-2016, 02:50 PM
sdbob sdbob is offline
Looks nice. My SD is 39k still has original exhaust.Not cut up. The car was rust proofed ,1st month with a grease type rust proofing. It's still soft. Blue Paint was bad when I first got it,still not perfect.They talked about repainting when new I said no.
Old 07-09-2016, 12:50 PM
Ron Landis's Avatar
Question Actually...
this is the very first unrestored car I've seen with the "USS" U S Steel stamping on the bottom of the gas tank. Every one I've dealt with has been on the topside. Anyone else have an original stamped on the bottom?
Old 07-09-2016, 01:23 PM
Held for Ransom's Avatar
Ascot Silver?
Late in the model year? Looks to have an Introl oil pressure transducer (sender).
Old 07-10-2016, 02:36 PM
Do you have pictures of the rare RA A/C oil tube?
I'd also like to see how it compares to the SD unit, if yours has A/C Bob.
Old 07-11-2016, 12:25 PM
HFR, The dipstick tube did attach to the rear upper AC bracket. I'll get a picture of it the next time I see the car (soon I hope).
Dennis
Old 07-12-2016, 11:15 PM
marxjunk marxjunk is offline
wow..that tank stamp is freakin perfect aint it.....
very few had them..because they where on the roll of steel and spaced out..for it to be so perfect...thats strange....never saw one either..
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 07-13-2016, 11:42 AM
X2...never saw one like that either. Dennis
Old 07-13-2016, 12:27 PM
No. Minimum options.didn't want power steering or brakes.but couldnt.did get radio then tape deck.I've driven mine to Norwalk at least 12 times.Raced a few times on Sun. 14.0 14.1.As delivered,never been apart.Just had fun.
Old 07-13-2016, 04:27 PM
And I've probably looked at it a bunch too. Just didn't remember the details.
Old 07-14-2016, 04:38 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Wow - that's an incredibly clean and dry HO Formula, Dennis! Thanks for posting thoise photos!
Regards,
"455HO" Lloyd
Old 07-15-2016, 07:22 AM
HFR, Here is the dip stick tube connector on the Formula; the uber-rare original flattened heat stove elbow on the driver snorkle to fit the valve cover (someone needs to repop this one correctly); and the RA Boot assembly.
Dennis
ID:	432745   Click image for larger version
ID:	432746   Click image for larger version
ID:	432747   Click image for larger version
ID:	432748   Click image for larger version
Old 07-15-2016, 07:27 AM
Original RA snorkel screens and fasteners; original Firestone 500 spare (appears never used); upper radiator hose spamping; clutch fan stamp; and origianl water pump.
Dennis
ID:	432750   Click image for larger version
ID:	432751   Click image for larger version
ID:	432752   Click image for larger version
ID:	432753   Click image for larger version
Old 07-15-2016, 07:29 AM
Your welcome Lloyd. I wish it was mine! Not too bad for a southern Ohio car. A lot of the bare metal has surface rust form sitting sooo long in a garage (since 2000?).
Dennis
Old 07-15-2016, 10:16 AM
superdutybob's Avatar
superdutybob superdutybob is offline
Wink
Dennis
Dennis
74 was the first year for the darker, almost brownish primer bath. I have a section of a dash that represents this color perfectly. It was the section where the dash speaker mounts.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 07-15-2016, 02:29 PM
Originally Posted by superdutybob View Post
Dennis
Didn't know that Bob. It is brown for sure, no red at all. This is an 01C build car (3rd wk of Jan. 1971).
Dennis
