Old 09-19-2020, 08:05 PM
grd777 grd777 is offline
Default plastic front valance
will i be able to use a plastic front valance on my 72 existing front bumper nose
Old 09-19-2020, 09:53 PM
cnc's Avatar
cnc cnc is offline
Do u have an original or aftermarket...???
It should fit from what I know I think 72-73 left factories with the plastic valance but were damaged easily and changed out to the steel ones...
I prefer the look of the plastic one...Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 09-19-2020, 09:55 PM
It should fit from what I know I think 72-73 left factories with the aplastic valance but were damaged easily and changed out to the steel ones...
no i am missing the valance
Old 09-19-2020, 10:00 PM
cnc's Avatar
cnc cnc is offline
I’ve also heard they require a lot of work or “ could “ require ....to fit correctly ....That was one reason why I decided to stick with the steel...
I see early birds offers a fibreglass unit...wonder how they fit....Chris
https://www.early-birds.ca/part_827_...98-125024.html
Old 09-20-2020, 09:23 PM
anyone else have any input on this
Old 09-21-2020, 08:49 AM
Judge273's Avatar
Judge273 Judge273 is offline
Bought a original and had to fix it.
Mike/Illinois
The Following User Says Thank You to Judge273 For This Useful Post:
Old 09-21-2020, 09:01 AM
necdb3's Avatar
necdb3 necdb3 is offline
Those noses look so much cleaner with the plastic panel. Car looks great!
Old 09-21-2020, 05:17 PM
looks great , did it bolt right up on the bumper or did you have do get different parts to install it
Old 09-23-2020, 05:15 PM
Transamric's Avatar
Original plastic valances will bolt to your bumper/lower fenders just fine. The lower center bracket to the rad support is different however. No biggie. A custom piece can be easily fabbed up.
I love the look of the plastic valances too, but nowhere as durable as the tin part.
Old 09-23-2020, 07:32 PM
metal is always better , but i really want the look of the plastic one
do u have a photo of that bracket
Old 09-23-2020, 07:46 PM
necdb3's Avatar
As long as you don't hit anything, the plastic holds up well.
Old 09-23-2020, 07:53 PM
johnta1 johnta1 is online now
I think it's this one?
(bolts to bottom of the upright for the hood release)
Old 09-23-2020, 08:19 PM
do u mean bracket number 6
Old 09-23-2020, 09:09 PM
Norwood's Avatar
Norwood Norwood is offline
Bracket 6 is available from Ames
Old 09-23-2020, 09:33 PM
great thank you
Old 09-26-2020, 02:20 PM
Who sells the best one
Old 09-26-2020, 04:31 PM
Brewster's Avatar
Brewster Brewster is offline
I have an original if interest?
Old 09-26-2020, 04:55 PM
Transamric's Avatar
Sure. As Norwood posted, a repro is available. But I'm showing a couple pics of two different designs brackets I've run across with plastic valance FB's I've parted. The one on the right is Pontiac #484749 and is the one I've found most often. The one on the left is an oddball. Never seen another one. This was off a fairly late '73 Esprit. Spacings are identical, in spite of the way it may appear in the pics.
Any one else seen another of this oddball?
Name:	plastic valance brkt #2.jpg
ID:	550343   Click image for larger version
Name:	plastic valance brkt #3.jpg
Old 09-27-2020, 07:26 AM
Brewster's Avatar
I have an original bracket not the actual Valance. Just wanted to make that clear. I did reply to the pm this morning. Cheers
Old 09-27-2020, 07:31 AM
That first bracket looks more like an exhaust manifold locking washer with bend over tabs that someone has made 'work'.
