Old 09-11-2019, 11:44 PM
Dragncar Dragncar is offline
Default Heads, whick one cools the center ex the best ?
Is there a consensus with the aftermarket PMD style heads as to which ones have the best cooling around the center exhaust ?
Is there much of a difference ? Tiger, High Port E head ect.
Old 09-12-2019, 05:56 AM
steve25 steve25 is offline
The E head pro port with its coolant feed hole in the center of the head.
A thermal coating applied inside the center ports on any head (especially Aliuminum) helps a good amount with burning head gaskets and extremes of thermal expansion that takes place there to chew up the head gasket over time.
Old 09-12-2019, 08:49 AM
slowbird's Avatar
slowbird slowbird is offline
So how much did the coated exhaust ports extend the life of head gaskets in your testing?
Old 09-12-2019, 01:22 PM
Available heads. Is there a difference ?
Old 09-13-2019, 05:58 AM
Can't say slowbird as the head gaskets have yet to fail, but test with a thermal gun show 45 degree drop in temp at the junction of the spark plug hole roll over point and the head surface just above the deck of the block.
Old 09-13-2019, 06:06 AM
In regards to common available aftermarket heads I can't say , but I would tend to think that a factory iron Block with its far greater gap in between each Bore and hence coolant flow would cool the center of the motor down each bank better then a aftermarket Siamese Bore block , or a near Siamese Bore block .
Just guessing here!
You can apply the same added center hose deal as the E pro port heads even to factory iron heads no less aftermarket heads.
The iron heads have plenty of wall thickness to drill and tap a 1/2" pipe hole in the side wall of the heads.
Old 09-13-2019, 01:11 PM
chiefbigb chiefbigb is offline
Ram air 5 layout
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 09-13-2019, 04:18 PM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
There are a couple of pro ports out and about. :-)
Name:	Pro port 1.jpg
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph
Old 09-13-2019, 04:36 PM
61-63's Avatar
61-63 61-63 is offline
I have dealt with old '61-'63 sd heads over the years and on one set of 980s someone had drilled a hole in the water jacket of the dual center exhaust on both sides and tapped them. I have no way of knowing if they had been NASCAR heads or drag race but the only reason they would have done this IMO would have been to install a heater hose pipe in that location on both sides to get the heat out more rapidly. Additionally I've had several sd dual quad intakes with additional threaded holes on the rear flanges both sides which too would have been to screw heater hose pipes in so heat could be more readily removed from the back of the engines/heads. These same tricks could be done on any Pontiac head. How efficient this was I haven't a clue.
Old 09-13-2019, 05:05 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
With a Billet head it doesn’t matter about any coolant mods.
Head gasket issues are a thing of the past.
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
Old 09-13-2019, 05:09 PM
GTOGEORGE's Avatar
With a Billet head can you make back to back passes or how does it work?
George
Old 09-13-2019, 06:36 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
Originally Posted by chiefbigb View Post
Ram air 5 layout
x2.
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
Old 09-13-2019, 08:22 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Ram air 5 layout
Chief Big B X3
67 Firebird 3440 lbs, Pump gas 537 IA2, tiger heads, 4.86 rear, 32 x 17.5's, full interior, 4 mufflers, street shape 1.36 60', 6.11@113.42 1/8 mi. 5.67@123 on small shot.
Old 09-13-2019, 09:55 PM
67'7F6'Bird's Avatar
DCI RAM AIR V
Name:	Steve Ram Air V Side Shot.jpg
Old 09-13-2019, 10:01 PM
slowbird's Avatar
Ram air 5 layout
But can the ra5 heads match or exceed the power potential of the other heads?
Old 09-13-2019, 10:34 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Before or after the head gaskets blow between the center ports? 😝
Go fast, see Elvis!
Old 09-13-2019, 10:41 PM
HAHAHAHAHHAH
Old 09-13-2019, 11:07 PM
We all know the RAV does away with that extra heat. High Port, Tiger or E head. Are they all the same or is one better.
I thought that High Ports had better cooling there. Do they ?
Old 09-13-2019, 11:08 PM
tom s tom s is offline
I STILL don't believe a head with a pushrod in the port will out perform NA head without.SHOW me!And I breath and bleed RA V!Tom
Old 09-13-2019, 11:21 PM
GTOGEORGE's Avatar
You know whats really funny.........you don't have to believe!
GTO George
