Old 09-20-2019, 12:22 PM
Do you have a traction bar or anything for the rear suspension?
Old 09-20-2019, 02:53 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Yes, Calvert bars
Go fast, see Elvis!
Old 09-20-2019, 03:03 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Pro-Touring F body has bolt on firewall-subframe bars liek the old Herb Adams strut bars.
Skip Fix
Old 09-20-2019, 04:30 PM
PAUL K's Avatar
That's exactly what I was thinking. I'll do something like the the PTF deal with a few improvements. I remember the VSE bars but never had a good look at them.
Go fast, see Elvis!
Old 09-20-2019, 04:54 PM
Yes, Calvert bars
I'd try putting more 'preload' or 'smack' if possible on the passenger side of the rear.
I'd also limit the travel of the driver front suspension some to let the front come up more level.
(for starters)
Old 09-20-2019, 05:46 PM
slowbird's Avatar
slowbird slowbird is offline
My car needs a cage, but doesn't have a roll bar. I don't race the car often but was planning on trying to level things out a bit by adding bars going from the firewall to the subframe and welding the bolt in frame connectors to the floor.
What work would you suggest for the rear suspension?
I'd be surprised if adding those bars help level the car out. I don't have those bars. But maybe in wrong.
Old 09-20-2019, 09:08 PM
PAUL K's Avatar
(for starters)
Okay, thanks for the suggestion
Go fast, see Elvis!
Old 09-20-2019, 09:10 PM
PAUL K's Avatar
You have a roll cage I don't....Thanks for your thoughts. Gotta try something
Go fast, see Elvis!
Old 09-20-2019, 09:24 PM
slowbird's Avatar
I think the roll cage is your best bet, but agree it's worth a try.
Old 09-20-2019, 09:38 PM
PAUL K's Avatar
Unfortunately a roll cage isn't an option
Go fast, see Elvis!
Old 09-21-2019, 10:11 AM
Skip Fix's Avatar
I still have some original Herb Adams bars. Those and the A6 compressor surer made getting to spark plugs a pain!
When you look how much the front subframe sags after you put jack stands under the front door/firewall area they have to help some.
Skip Fix
Old 09-21-2019, 11:59 AM
PAUL K's Avatar
I agree....are the installed currently? Would it be much bother to post or email me a couple of pictures?
Go fast, see Elvis!
Old 09-21-2019, 12:27 PM
Skip Fix's Avatar
Paul they are off the car but in the garage. I can snap some pictures for you.
Skip Fix
Old 09-21-2019, 12:34 PM
PAUL K's Avatar
Thanks....he made cool stuff. I have a set of his road racing shocks.
Go fast, see Elvis!
