Old 01-21-2024, 12:39 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Default T3 Headlights, any Value?
Hi all
I recently acquired some parts from a gentleman that restored some Pontiacs and he saved a lot of things. I have some T3 headlights that are supposed to be good as he checked them before removal. Most are 2 prong High beam but may have a couple of low/high combo. Are these worth anything to anyone or should I just trash them?
Thanks for the insight
Old 01-21-2024, 01:48 PM
Lightfoot's Avatar
Don't trash them! They definately have collector value.
I don't know what the going rate is, but someone on eBay is bound to pony up near 'market value'.
Or try craigslist.
If you don't do internet selling, bring 'em to a swap meet.
I'd test them all with jumper wires to a battery to verify which ones worked.
The Following User Says Thank You to Lightfoot For This Useful Post:
Old 01-21-2024, 01:55 PM
Lightfoot's Avatar
I shouldn't say collector value by themselves, as much as they add value to concours restorations on period cars.
Old 01-21-2024, 02:39 PM
65madgoat's Avatar
I would only have a T3 or reproduction T3 on a correct appearing or properly restored car.
Anything else and a complete turnoff. Especially those new lame HOLLEY lights.
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 01-21-2024, 02:40 PM
65madgoat's Avatar
Good used T3 bulbs go for $25+ each usually.....
The Following 2 Users Say Thank You to 65madgoat For This Useful Post:
Old 01-21-2024, 04:34 PM
Stuart's Avatar
Stuart Stuart is offline
They changed the T3 logo periodically, so you can determine their approximate age. There are links online that show the different styles.
The Following 2 Users Say Thank You to Stuart For This Useful Post:
Old 01-21-2024, 06:27 PM
Jeff Hamlin's Avatar
IMO If you're after a correct look, I recommend these;
LINK> https://www.lectriclimited.com/lighting-fuse-flashers
I can't see anyone paying $25 for an old bulb, but as they say...
ID:	626920   Click image for larger version
Name:	2005 DAY x.jpg
Old 01-21-2024, 06:58 PM
65madgoat's Avatar
You pay $25 for 1 because Lectric only sells new repop bulbs in sets of 4...
Old 01-21-2024, 07:44 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
The assembly line T-3’s have a inked date code on the back side of the bulb.
ID:	626927   Click image for larger version
ID:	626928   Click image for larger version
ID:	626929   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 01-21-2024, 08:44 PM
ponchjoe's Avatar
Thanks for posting that! I’m pretty sure these are all 60-67 but will be able to check now. And I’d make make someone a deal on all of these.
The Following User Says Thank You to ponchjoe For This Useful Post:
Old 01-21-2024, 10:12 PM
Half-Inch Stud's Avatar
Run the headlight GND wires to the Alternator Case rather that the Rad Support for BRIGHT T-3 performance.
Old 01-21-2024, 11:41 PM
65madgoat's Avatar
I am seeking 1972 era T3 headlights 7" round if anyone has a pair....
