Old 09-19-2020, 09:53 AM
Tom Hand's Avatar
Tom Hand Tom Hand is offline
Exhaust Guru
Default Six more finished, two to go!
Finishing the last two of this batch of eight VOE mufflers.. Getting good at them but the price of materials keeps them rather high dollar. But, other than the actuator, they are pretty much all 304 stainless steel.
ID:	549891   Click image for larger version
ID:	549892   Click image for larger version
Tom Hand
The Following 3 Users Say Thank You to Tom Hand For This Useful Post:
Old 09-19-2020, 12:09 PM
Cardo's Avatar
Cardo Cardo is offline
Man those are nice Tom! Those put the "Art" in industrial arts.
"I know just enough to keep me here, but not enough to get me out"
Old 09-26-2020, 12:05 PM
Tom Hand's Avatar
Exhaust Guru
Finally had the time to test these on my 340 Barracuda. I have my own 2.5" versions I run all the time so this car is used to them.
Note that these sound level readings will be higher on a 400 Pontiac with 2.25" tailpipes that are longer and have tips. Mine neck down to 2" right over the axle and I have no tips on them during testing.
All values are recorded at 10 feet from the tailpipes' outlet. Humidity is 66% and temperature is around 77 degrees F and wind is light here today in the KC, MO area.
Idle 750 rpm: valve is closed: 66.5 dBA; valve is open: 76 dBA
2200 rpm: valve is closed: 79 dBA; valve is open: 90 dBA
3500 rpm: valve is closed: 85 dBA; valve is open: 94 dBA
These are working and sounding like the others made in this batch. These are destined to be used on a 70 GTO but can't recall if it is a true VOE GTO or not.
Two more to go and I am finished!
Tom Hand
Old 10-04-2020, 02:41 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Do you sell these if so where can they be bought?
Old 10-07-2020, 08:33 PM
Tom Hand's Avatar
Exhaust Guru
Greetings, I built these eight for a special car and its owner. I am out of parts now and likely will not be doing anymore. They are very expensive due to the labor involved in welding and the price of 304 stainless steel internal parts as well as the cost of the custom made actuators.
Tom
Tom Hand
Old 10-07-2020, 11:24 PM
gtokid1968's Avatar
thanks
