Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 10-30-2020, 07:40 AM
AIR RAM AIR RAM is offline
Default Butler Performance PRO 80psi Oil Pump BPI-M54F-PRO
As the title states, I have a brand new, never used, never installed Butler Performance PRO 80psi Oil Pump BPI-M54F-PRO for sale. Selling because I have decided to step up to a different Oil Pump for my Turbo 496 build.
Pump Description from the Butler Website:
"This oil pump is a Butler Performance exclusive! This pump has been completely re-machined, blueprinted and tested to be what we feel is one of the best Pontiac oil pumps on the market. We now also offer this same PRO pump in a 60-65 psi version for the those of you that want a high quality oil pump but have a milder combo that doesn't require 80+ psi of pressure- See part# BPI-M54DS-PRO for the 60-65 psi version. Both include:
anti-gall/ anti-cavitation dimples in bottom of both gears
Extra thick diamond lapped .250" oil pump plate
Tops of Gears machined with 360 degree oil grooves to prevent galling against plate
Drive shaft bore supplied with oil groove/ micro polished drive shaft
Pump gear pedestal pads diamond lapped and supplied with oil groove
Idler gear honed and oil weep hole added
Gasket surface diamond lapped
Bypass ball and sealing surface machined/blueprinted
Bypass spring tested/blueprinted
Copper gasket included
Flow chart included
Includes extra shim for adjusting spring pressure 5-10 lbs
Features oil retention points on each tooth to prevent galling on the plate
Due to the thickness of the plate on the Pro pumps, when using a pickup with a mounting tab, a slight modification of the tab may be necessary. This can easily be done by bending the tab up and elongating the mounting hole.
We recommend a 1/8-1/4" oil pan to pickup clearance. Must be checked with all pumps and pickups regardless of oil pan."
Asking $159.95 with Free Shipping!
Here is a video of the Pump (Better than pics):
https://youtu.be/72Umb_fP1Rc
If you have any questions or concerns please feel free to contact me.
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 11-03-2020, 08:27 PM
Still for sale.
See Video for close up details
SPEED SAFE, NICK
Old 11-06-2020, 07:14 PM
Still for sale.
SPEED SAFE, NICK
Old 11-13-2020, 08:01 AM
Still available!!! This is a brand new 80lb Oil pump that has been through the "Butler Process".... If you wanted to lower the PSI you can easily remove the washer below the spring or add a washer to raise it.
SPEED SAFE, NICK
Old 11-16-2020, 07:23 PM
SPEED SAFE, NICK
Old 11-20-2020, 01:44 PM
Click the image below for a direct link to purchase this pump. Use Pay Pal or most Major Credit cards.
Click image for detailed YouTube video of pump:
SPEED SAFE, NICK
Old 11-23-2020, 02:29 PM
SPEED SAFE, NICK
