Old 09-24-2020, 09:28 AM
ejgoat ejgoat is offline
Default Insulation
Can,t figure out where the under dash insulation goes on a 1964 gto, no instructions, can you guys help
Old 09-24-2020, 02:02 PM
dld's Avatar
dld dld is offline
do a search. here is one thread
http://forums.maxperformanceinc.com/...10#post4618110
Old 09-24-2020, 02:03 PM
Cardo's Avatar
Cardo Cardo is offline
It glues to the bottom side of the top of the dash. Off to the left and right side of the dash speaker if you will. It would go in the spot where the insulation stops in this picture. A lot of people don't use the factory style insulation because it tends to fall apart. I used what is in the picture instead.
Old 09-24-2020, 02:06 PM
dld's Avatar
dld dld is offline
if your using the the aftermarket stuff its not correct at all . I don't think to many ppls are going to get to fired up if its wrong material. I have never found anything close to the factory material
Old 09-24-2020, 08:18 PM
John V. John V. is offline
Went thru this with my '64 convertible.
Here's the thread where I got a lot of input and help.
IIRC, we just went with the repro stuff, probably from Ames.
http://forums.maxperformanceinc.com/...d.php?t=804139
Includes the factory diagram showing all the insulation.
Old 09-26-2020, 11:00 AM
Dick Boneske's Avatar
The factory under dash insulation was some really nasty stuff. It was a fiberglass mat, similar to the insulation used in walls in our homes, except it was thin. Every time I'd work under the dash, pieces would fall in my face. I don't think the OEM material did much to deaden sound.
When I restored my '64, I removed all the old insulation and used the foil-backed material from Home Depot designed for heating ducts. It's about 5/16" thick and has adhesive on the side opposite the foil.
Name:	GTO Dash Installed 9-2-2010 005.jpg
ID:	550322   Click image for larger version
Name:	GTO Dash Installed 9-2-2010 006.jpg
ID:	550323   Click image for larger version
Name:	GTO Dash 8-31-2010 005.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
