Old 07-30-2020, 10:08 PM
Erik_ Erik_ is offline
Default For Sale: 1968 Pontiac Tempest
*LOCATED IN HARLEYSVILLE, PA (Zip code: 19438)
For sale I have a 1968 Pontiac Tempest. It is a Pontiac 350 with a two speed column shifted automatic. It runs and drive well other than the transmission leaking out of the speedometer cable hole. I am going to try and find time to replace it before it sells. The car is rust free, but mostly bondo from the previous owner it seems well done.Since I’ve owned it I’ve put Wilwood front disc brakes on and replaced the rear drums and shoes. I also replaced the booster, master cylinder and brakes lines. It is a solid foundation for a great project car.
Needs/Issues:
-front and intermediated parking brake cables
-front and rear seat belts
-needs tires
-needs exhaust
- new light sockets front and rear (also missing front parking light housing and lamps)
- hood alignment and driver side door alignment is jacked, guessing from when previous owner worked on car.
-trans needs vacuum modulator hooked back up, I don’t know of any internal issues it seems to shift okay.
- I noticed when I was replacing the rear drum brakes that the axle shafts have excessive end play.
I have miscellaneous parts that I bought for it that will go with car.
I just don’t have the money or time to build it the way I want it.
Hoping to get $9500 but will consider all reasonable offers.
For an extra $1000 I will include a 1978 WA code Pontiac 400 short block and 1969 Ram Air 3 cylinder heads, along with a brand new Edelbrock Torker 2 intake manifold. The block is in very good shape, the cylinders are in good shape and has never been bored. The bottom end is also in very good shape. If you are interested I will send pictures upon request.
ID:	546154   Click image for larger version
ID:	546155   Click image for larger version
ID:	546156   Click image for larger version
ID:	546157   Click image for larger version
Thread Tools
Display Modes
