Old 09-10-2020, 04:03 PM
sweetgto sweetgto is offline
Default 65 over sensitive brakes
Changed my power brake booster for cosmetic reasons. Since change any pressure on pedal other than light causes all wheels to just about lock up? Put old booster that was working good back in, same result? Checked all wheels for leaks look fine. Re adjusted all , still same. Used same length rod to master, linkage in correct lower hole on pedal. Don’t know what I did or didn’t do correctly? Any help appreciated, thanks
Old 09-10-2020, 10:30 PM
389 389 is offline
The lower hole gives 6:1 ratio, you want the upper hole at 3:1....
Old 09-11-2020, 06:07 PM
Thanks for reply, could be wrong but read or thought that upper hole was for manual brakes?
Old 09-12-2020, 04:13 AM
Geoff Geoff is offline
Sweet, you are correct, post #2 is incorrect.
Old 09-12-2020, 03:59 PM
Thanks,Geoff
