Old 11-06-2012, 01:32 PM
chrisinestes's Avatar
chrisinestes chrisinestes is offline
Default Running coolant system stop leak with a block heater
My '99 GMC 5.3 V8 leaks coolant unless I run sealer in it. I have a freeze plug block heater I'd like to put in for those sub zero morning starts. The block heater directions say the sealent will shorten the life of the heater... which makes sense. How much time will it take off the heater? Are we talking 4 years instead of 5 years... or 3 months instead of 5 years? Any ideas?
Chris
Cum Catapultae Proscriptae Erunt Tum Soli Proscripti Catapultas Habebunt.
Old 11-06-2012, 01:52 PM
sleepy's Avatar
sleepy sleepy is offline
Have the leak fixed rather than useing a patch product.
Why is he not suspended?
Old 11-06-2012, 02:02 PM
I would, but I can't find the hole. No drips... No coolent oder in the cab... No exhaust gasses in the coolent...
Old 11-06-2012, 02:13 PM
sleepy's Avatar
Sounds like intake. They are plastic and tend to leak into the cylinders.
I don't like stopleak. It collects in the bottom of the water jackets reducing flow around the cylinders and plugs the heater core.
Old 11-06-2012, 08:52 PM
77 TRASHCAN's Avatar
Leaking intake is a fairly common problem, just get it fixed. I still wouldn't have a stinking FORD...
Shut it off
Shut it off
Old 11-06-2012, 08:55 PM
Would fixing a leaky intake a matter of new gaskets, or does it mean getting a new intake manifold?
Old 11-06-2012, 09:02 PM
sleepy's Avatar
Most likely new gaskets.
Old 11-07-2012, 10:16 AM
Trulyvintage's Avatar
Trulyvintage Trulyvintage is online now
Lightbulb Day to Day
Chris,
Your truck is gonna be 14 years old soon ....
If you need block sealant to keep it running, keep using it.
I would not mess with freeze plugs unless they are leaking
or look like they are ready to corrode away ....
If you start every day from home or somewhere with a 120 VAC power source,
you might try an alternative heating source for your engine to help with cold starts
like an electric blanket .....
Jim
Old 11-07-2012, 01:02 PM
Originally Posted by Trulyvintage View Post
Chris,
Jim
Yeah, I think I'm going to leave well-enough alone. I'm going to look for some other way to get some heat in the block. It's not that it won't start because it's cold, it's because I'm getting soft in my old age!
Old 11-07-2012, 01:30 PM
pggto's Avatar
pggto pggto is offline
Remote start and let it warm up. Or get the type of heater that splices into the lower radiator hose (if they still make them)
Old 11-07-2012, 02:47 PM
GT182's Avatar
GT182 GT182 is offline
Get an inline heater for the hose going to the heater from the water pump. it will pump warm coolant thru the system better than one for the lower radiator hose.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 11-08-2012, 08:29 PM
They are still made....most parts stores should have access....depends a lot to the counterperson you talk to, beware.
Ask for the manager, if needed. If you hit a deadend, call around. I like the lower hose heaters. Sold a few, in my parts store days, even in Oklahoma...LOL
If you use a lower hose heater, you will need to find a section of hose that's straight for about 4-6 inches to mount the heater. I advise to buy a new lower hose when doing this, just cheap insurance...
Shut it off
Shut it off
Old 02-28-2013, 02:15 PM
Well, I finally got to working my water leak/block heater. The 5.3 in my truck has a dry intake manifold & a windage tray... kinda like a Pontiac. It seems to have been the water pump leaking. It finally got bad enough that I could see coolant coming out of it. I got a NEW WP, and replaced all 7! coolant hoses on the thing... 7 pressurized hoses!
I put a block drain heater in it. Nobody sells an inline-hose heater for it. Seems the vehicle has to be running in order for the coolant to circulate.
So far so good. No leaks detected, and no stop-leak in it.
Had to replace the PS pump and the steering box, too. Bring on the next 221,000 miles!
Chris
