#101
Thank you for the information. I have updated the list. Stan
#102
Opeliac has a impressive car. Not familiar with "191" heads. Are they 197 ? 191 a typo ? If not, what are the heads what was the CR of that engine ? |
#103
Stan
#104
Can you split up the pump gas list, NA with PMD heads and block ?
#105
I was just kidding Stan, my home brewed octane booster (Toluene based) makes genuine race quality fuel - C12, C16 etc. We sell it for race use/fast road/motocross bikes etc.
#106
Stan
#107
Here is my dad's combo from 1995
1965 GTO 3720lbs 462ci 197 HO heads 65 tri-power 455SD rods TRW pistons H-O racing HC-04 hyd cam Best of 7.07@96 in 1/8, 11.07@119 in 1/4. Run was in July in midwest so air was crap im sure. |
#108
Thank you for the information. I have added it to the list. Is this car / engine or you '73 Ventura I have on the list run on pump gas? Stan
#109
1970 Firebird
1970 Firebird built in 1997.
3200 lbs. without driver back-halved with ladder bars and single adj koni coilovers 29.5 x 11.5 slicks 12 bolt with 4.56 gears 400 ci engine, .065 over, 3.79 offset ground stock crank, 10:1 comp. 6.8" bbc alum rods #62 heads ported by Dave Bisschop, 270 ish cfm @28" solid roller cam 276/283 @ .050, .620 lift 1150 dominator carb with Victor intake and 2" spacer TH400 trans brake trans, 8.5" converter best time: 10.51 @ 126.5 mph, launch at 3000, shifting at 6000 rpm 1.41 60ft. dynoed at 608hp @6700 at flywheel there is more left in it, but it is over 23 years old now, and I don't want to break it. Getting ready to pull it and freshen it up for next year |
#110
Thanks. Stan
#111
The GTO could have ran on pump gas back then Cam2 was cheap so that's what we ran. |
#112
Driver weight..... err... 255lbs. But hey, I'm 6'-6"! Yes, I run Cali 91 octane in it. My guess would be that it is making around 525 -550 ish hp in it's current state.
#113
Thank you. The cars are on both the PMD and Pump Gas lists. Stan
#114
Stan
#115
Stan,
Another reasonably successful OEM block and head combination we put together for Milt Milton's 1966 Bonneville 1973 455 block, .040” over, block filled to water holes, lifter boss reinforced, JE flat top pistons gas ported, .043"/.043"/3mm ring pack, Eagle forged 4.250” crank, 6.800” Eagle rods, #48 heads race ported, 2.11”/1.77” valves, Scorpion 1.65:1 stud mount rockers, Isky solid flat tappet cam 270/280 @ .050” dura, .680” lift, 12.6:1 compression, ported Victor, 950 HP Holley, 1” spacer, Canton deep oil pan, 1-7/8” Doug’s headers, 3.5” collectors with 18” extensions, 8” Munsinger convertor, Original TH400, Original ’66 rear end housing/axles w/3.23 gear (Duerst gears), 29” slicks. Engine dyno’d at 771 HP 4500 lbs race weight (yes it weighs 2.25 tons) Best 10.86 at 125.8 mph at 3185’ Density altitude Seem like a good heavy car/small carb/solid flat tappet combo to add to your list. Jim
Jim www.raceV8s.com 1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th. |
#116
OK, you win. |
#117
Thank you. Stan
#118
Stan
#119
You must think people hang on you hijacked lists every word. Many don't. Plenty of guys don't want their cars to be part of it.
#120
But like normal you know nothing, but act like you know everything. Stan
