Old 12-19-2020, 07:19 AM
Default 12 volt heater feed
I posted this under electrical also. Can anybody tell me where the voltage for the heater originates (fan etc) in a 1962 full size Pontiac? There is no fuse in the fuse box.
Old 12-19-2020, 11:33 AM
pfilean's Avatar
pfilean pfilean is offline
Should be a 14A fuse at the lower right of the fuse box just above the wiper fuse. Only hot with key on. Of course the switch may not be making contact or the speed controlling resistors may be bad or some of the connections may be loose.
Old 12-19-2020, 01:47 PM
From Service Manual:
Fuse at lower right above Wipers/Back-up lamps.
(as pfilean said)
ID:	556500   Click image for larger version
ID:	556501   Click image for larger version
Old 12-19-2020, 10:02 PM
Thanks. That fuse on my fuse box is labelled "SPEEDO". I'll check the circuit and see if it goes to the heater.
