Old 10-26-2022, 09:59 PM
wooftfd wooftfd is offline
Default Help with Rod ID
Have a set of rods, reportedly Super Duty... Pics below, no numbers that I can find, marked GM ANY IDEAS?
Old 10-28-2022, 03:22 AM
242177P's Avatar
242177P 242177P is offline
Seeing as how nobody more knowledgeable than me (that's a lot of people) has stepped up...
IIRC, all the 58-62 rods were forged. Could these be good ones? Without any way to ID them odds are against it. Don't abandon research, it beats regret. I'm just steeling you for a possibility. Hope for the best, but prepare for the worst.
Surest way to know if they're the regular rubber rods would be finding someone who can perform a hardness test on them. Brinell numbers are known. Sounds expensive though? Dunno, never looked into it.
The Following User Says Thank You to 242177P For This Useful Post:
Old 10-28-2022, 03:43 AM
Kenth's Avatar
Kenth Kenth is offline
I would say 1963-1965 1/2 #544956 421 H.O. rod.
In general, widths of the big end of the Pontiac rods are .995", and the small ends are 1.250".
Exceptons are
1958-63 S.D., .985" big end.
1973-74 S.D., .990" big end.
1969-70 RA V, .985" small end, .990" big end.
Lots of info on rods in Pete McCarty´s second book.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
The Following 2 Users Say Thank You to Kenth For This Useful Post:
Old 11-09-2022, 08:04 PM
pont406's Avatar
pont406 pont406 is offline
Smile
If you measure the rod from under the rod bolt head to above the rod nut, if it is exactly 2 inches, its an SD rod! other rods are 1 15/16th when measured the same way
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
